Results 1 to 11 of 11
Thread: 260 hesitation/falling issues
03-22-2017, 09:57 PM #1
sup fellas....got a 260 on a boat we having problems with..
motor = stock 260 running brucato with 39lb curve
motor is falling out when you stab the throttle...happens at all rpm....if you pedal it motor comes back and runs good....if you stab from idle and dont pedal it ...itll cut out
checked psi ....its holding
9amp stator....
first time messing with a horn motor so feel free ..............81' HYDROSTREAM VECTOR / slightly Modified 200
03-23-2017, 06:34 AM #25000 RPM
- Oct 2004
- umatilla,FL
- 247
- 7
- 45
- 46
sounds like its loosing ground in ecu check harness just had one doing this with a mercury box would run all day below 3000rpm stab it and was like pulling kill switch and it would catch up and stay running. had to replace my harness
texasvector thanked for this post
03-28-2017, 06:36 AM #35000 RPM
- Oct 2004
- umatilla,FL
- 247
- 7
- 45
- 46
had any luck with it yet ?
03-28-2017, 07:09 AM #4
9 amp and efi don't play well together "most" of tha time.... least when i tried it way back when... ya NEVER see one come outta tha box with one.
WillySteve liked this post
03-29-2017, 06:48 AM #5
cleaned injectors... same same....stator next
03-29-2017, 07:56 AM #6
Completely different fuel rail, injectors, and regulator!
Modded Hydrostream Vking
Hydrostream Vking
Hydrostream Viper
Sold, Hydrostream Vector, Allison xb2002
03-29-2017, 08:25 AM #7Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
sounds like
MAP issue? does it have TPI?
hose, fittings sensor in pack?
but i'm an OMC guyLast edited by powerabout; 03-30-2017 at 09:20 AM.
03-29-2017, 08:29 AM #8
Cleaned all fittings going to the horn with carb cleaner. Talked with texas and think the stator and trigger are our next bet as suggested
Hydrostream Vking
Hydrostream Viper
03-30-2017, 04:15 AM #9
Map sensor fitting on the bottom of the horn right side is clogged . Keep it clean with a small paper clip and needle nose pliers , attach a piece of hose and flush with carb cleaner . This will more than likely solve the problem .
texasvector thanked for this postWillySteve liked this post
03-30-2017, 07:37 AM #10
^^x2^^
WillySteve Hendricks
20XDC Bullet/Modified Merc 260
295TF Charger/ProMax 225x-Sold!
'83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
'85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
Freedom 240 DLX Fisher Toon/Merc 115
10' Cougar Cub/Merc 25HP On The Bottle!
18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
03-30-2017, 07:23 PM #11
Winna winna.....chicken dinna......fitting was clogged.....u could spray cleaner through it just fine....ran some wire through it...unclogged and running like a mule now
Thanks tom and others!81' HYDROSTREAM VECTOR / slightly Modified 200
The Sky Is Falling
By INXS in forum The Scream And Fly LoungeReplies: 7Last Post: 12-20-2007, 12:20 PM -
Why is the price of gas falling?
By captcarb in forum The Scream And Fly LoungeReplies: 30Last Post: 01-29-2007, 12:40 AM -
my skirt keeps falling off
By PARKER RABE in forum Technical DiscussionReplies: 27Last Post: 10-06-2006, 04:55 AM
