Results 1 to 5 of 5
    Mar 2010
    houston, tx
    Adjusting pulley cable steering
    How tight should this be?
    Mine seems loose after we adjusted it , it's a bear to try and hold the steering straight and pull the cable tight and tighten down the clamp at same time.
    This is is on an xr2001 with wing plates any tips would be appreciated!!
    Gravenhurst, Ontario.
    I get my kid to hold the steering wheel straight and I tighten the cables and clamps.
    its not difficult to get it tight, it's next to impossible to get tight with the wheel straight.
  3. Likes Michael J Giesler liked this post
    SE MN
    That's what turnbuckles are for.
  5. Likes HStream1 liked this post
    Mar 2010
    houston, tx
    Quote Originally Posted by CNC_Guy View Post
    Yeah I was surprised there are t any
    Aug 2004
    Charleston, SC
    Lower the motor a little (maybe 1/2" or so), get it as tight as you can, then raise it back to where you want it. Alternatively....if you're running a 15" with the Alli wings, it probably won't maintain the same tightness while trimmed all the way down as it will at level or all the way up. Find where it is most loose and make that the point where you pull it tight. At a minimum, you want it tight enough so that you can't pinch the two cables (from pulley to anchor point) and make them touch.
  8. Thanks 90 5.0 thanked for this post
    Likes bullwhipjkg liked this post
  1. STV cable-pulley steering
    By Mo River Rat in forum Technical Discussion
    Last Post: 04-07-2014, 12:30 PM
  2. Replacement cable for cable and pulley steering system
    By GTRMick in forum Props, Setup, and Rigging
    Last Post: 12-09-2013, 07:11 PM
  3. Cable and Pulley steering
    By rbengines in forum Props, Setup, and Rigging
    Last Post: 01-31-2012, 04:19 PM
