Results 1 to 6 of 6
Thread: Water temp gauge on a 2.4 carb
03-16-2017, 02:57 PM #1
Where would be a good place to install the sensor on a water temp guage on a carbed 200 2.4.
Electic guage 1/8" npt sender
roadkill636 liked this post
03-16-2017, 08:21 PM #2
Decided to drill and tap port head like my 2.5 high po heads already have that in them
WillySteve liked this post
03-16-2017, 08:41 PM #3
I was thinking same thing, but was unsure if there may a reason not to on a 2.4.
03-16-2017, 10:31 PM #4
Couldn't you just put a brass T where the water pressure gauge goes and use the other side of the T for your gauge. Don't wanna see you crank in a pipe thread hole and stress out the block and crack it under heat and vibration loads. The aluminum is usually built up where ever the factory has a hole in the block.
03-17-2017, 02:49 AM #5
I thought about that and I think the waters cooler there
i looked at both heads a lot first and to see if there was any noticable reason not too couldn't find any so I drilled and tapped both sides just in case I want to move it at some time or run a second gauge for any reason.
03-17-2017, 07:31 AM #6
Oops, for some reason i thought you were wanting to drill the block.
***water temp gauge***
By catfish123 in forum Technical DiscussionReplies: 7Last Post: 09-15-2023, 08:30 PM -
1980 BlackMax 200 Water Pressure Gauge and Temp Gauge Installation
By mwidden in forum Technical DiscussionReplies: 2Last Post: 09-04-2014, 05:33 PM -
Temp + water gauge
By bucket in forum Technical DiscussionReplies: 3Last Post: 04-04-2002, 07:07 AM
