Results 1 to 10 of 10
03-15-2017, 11:21 PM #1
Bolt on cav plate and/or bottom plate on jack plate for an STV Euro
Wondering if anyone has had any experience with a bolt on cavitation plate and/or plate that bolts up to the bottom of a jackplate to redirect the water flow on an STV euro...will be racing and mainly lake cruising...wondering if it's worth it or not... thanks
15.5 cobra 175 hp merc - sold
18 tahiti tiger O/B 200 hp merc - sold
19 STV euro - 2.5 merc DRAG
Seebold F1 tunnel - 2.0 F1/champ
03-16-2017, 07:46 AM #2Junior Member
- Dec 2016
- MS Gulf Coast
- 24
- 9
- 9
No expert,but fabbing a jack-plate plate is one of my next projects on my pro comp.
03-16-2017, 08:24 AM #3
If you look on the Allison Boats website they have info on the "planning foil" and the "skid planer": http://www.allisonboats.com/content/specials/
03-16-2017, 09:05 AM #4
Good info on the ally website... I'm kinda more interested In how it has worked with a euro...benifits, pros and cons etc... if it's a worthwhile bolt on for racing... running a hipo 2.5 merc 245hp
03-16-2017, 03:14 PM #5
If you care about holeshot you will need them both.
Buddy has a euro with a little more hp than me and at same weight i put 2ish boats on him out of the hole religiously he has neighter on his euro and I have both on my bullet.
We are running same gear and prop combination too
03-16-2017, 03:37 PM #6
I have a plate on my GS bolted to the bottom of the jack plate that I fabbed up my self. Helped hole shot and keeps boat on plane at slower speed than without. And once it's up on the pad it's not even touching the water, so it effects nothing after that. Works for me.
03-16-2017, 05:35 PM #75000 RPM
- May 2001
- Maine
- 979
- 35
- 41
- 169
It would be interesting to see what happens at the 60-70 mph bounce with the plate.
03-16-2017, 05:54 PM #8
pro's both are good for holeshot, none of them will work when your going fast (unless your sinking). great for going slow and still seeing over the bow.
con's of the foil is no matter who makes them they are an ugly thing on the motor, that is the only downside to one I have found using them for about 30 years..
the plate under the jack plate again no cons that I know off, but I have not used one of them "yet".
I am going to make one similar to an Allison drag plate when I find some material, but even the cheapo doel-fins do actually work pretty good.
in the uk the doel-fin is the most popular foil youl find on a boat, because we only have a couple to choose from and with the plastic ones the doe-fin is the better one.
03-16-2017, 07:18 PM #9Member
- Sep 2013
- Knoxville, TN
- 68
- 16
- 24
03-17-2017, 12:26 AM #10
you 100% need a cav plate for sure, the one under the jackplate wont hurt anything and could be an asset
Allison XB02, 22ft Tritoon 225 4 stroke, two seadoo sparks
Past rides 2001 STV EURO, Allison Grandsport, STV RiverRocket, STV Euro, STV ProComp, Hydrostream V-King
RIP RPM RACING
RIP GTS1
Bolt patern on jack plate
By RSM in forum Technical DiscussionReplies: 2Last Post: 09-28-2007, 09:37 AM -
Jack Plate Bolt Pattern
By Flatlander in forum Technical DiscussionReplies: 2Last Post: 06-26-2006, 07:34 AM -
Jack plate bolt pattern?
By Ryan140 in forum Technical DiscussionReplies: 1Last Post: 11-05-2004, 09:32 PM -
jack plate bolt pattern?
By still-floatin in forum Technical DiscussionReplies: 14Last Post: 01-04-2004, 09:14 PM
