Results 1 to 15 of 69
Thread: Core Removal on Allison
03-13-2017, 08:00 PM #15000 RPM
- Sep 2014
- piedmont S.C./hickory hill TN.
- 187
- 11
wanting some tips on what methods and tools are needed to remove balsa core.thx also just found some faxtory holes in hull!!!1/4" holes from the inside walls to floor panels. they holes match exactly to the ones in the panels.best way to fix.i have my idea,always listening to others ideas.
03-13-2017, 08:10 PM #2
Tyvec suit, dust mask, various implements of mass destruction. It really depends on what shape the core is in as to how you remove it. If it's totally rotten you can sweep out the remnants with a broom and dust pan. If it's still pretty solid you may have to cut a cross hatch in it with a circular saw (careful with the depth so you don't cut through the hull) and wreck it out with hammer, chisel, pry bars, cuss words, adult beverages, etc....
Good luck and post pics!Josh Peterson
hydrostreamvking4m, RIVERRUMMER 70 liked this post
03-14-2017, 08:22 AM #35000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
Never again will I use a circular saw on a hull that I am not cutting up for trash. Hammers, chisels, and pry bars have their place but make it extremely easy to damage the outer skin, especially on one with a light mold form like an Ally. Tool of choice would be something like a versa-tool (oscillating cutter) with carbide saw blade. Cut as close to the hull as possible because what is left will have to be sanded/ground out. I use a small 4" grinder with with usually a 30g disc. If you make divots in the hull during the grinding, I would first apply a skim coat of putty to create a level and even surface to begin re-coring from.
W2F a V-King liked this post
03-14-2017, 08:54 AM #4
Some guys have had good luck with a looonnnnngggg blade on a reciprocating saw too...
You will just have to play around and find something aggressive enough to work without damaging the outer skin of the hull!Josh Peterson
03-15-2017, 08:18 AM #5
03-15-2017, 10:22 AM #6
Once you get the big stuff out a wire cup brush on a 4" angle grinder works good for the final clean up.
Josh Peterson
03-16-2017, 04:36 AM #7
any photos ? would be good for others to see what's happening and how you doing it !!
03-17-2017, 01:07 AM #8
I used a home made chain saw disk on a 9" grinder works great. King Arthur tools sells a small one but you'll only be removing ~2" Strips at a time. I also used Milwaukee pruning sawsall blades 5 teeth per inch, specifically Milwaukee others are similar but the blades broke 10x faster. I would stay away from any pry bars and hammers you will cost yourself more time and money than you save. I was removing a fairly solid core it was just waterlogged.
03-17-2017, 08:01 AM #95000 RPM
- Oct 2011
- Ontario
- 370
- 32
- 46
- 336
- 134
- 7 Post(s)
Man what a headache, might have to tackle a job like that this spring.
03-17-2017, 08:05 AM #105000 RPM
- Sep 2014
- 187
- 11
sorry for no pics,dont have the know how. I have made good progress with a oscillating multi tool with the "JAPAN" style wood blade .pretty aggressive teeth 12 teeth per inch.the core is water logged from the previous owner drilling 1/4$" holes all the way thru the hull!!!.1/3 the way done on the core removal.did not really want to go into floatation boxes at the rear,but there are some questionable spots.still on fence as to wat core replacement material I waill use.I know balsa is great,but I am leaning twards something that will never "ROT'
03-17-2017, 08:10 AM #115000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
IMO remove the flotation and throw it away
03-17-2017, 09:01 AM #12
03-17-2017, 10:22 AM #13
The alternatives may not rot but can become waterlogged, so workmanship is key.
03-17-2017, 10:52 AM #145000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
03-17-2017, 11:44 AM #15Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I used the King Arthur lance-a-lot on my core removal with very good, fast results.
hydrostream core removal
By mad man in forum Fiberglass and Composites DiscussionReplies: 66Last Post: 03-21-2017, 04:16 PM -
Another core removal method.
By DavidW in forum Fiberglass and Composites DiscussionReplies: 8Last Post: 04-02-2013, 02:59 PM -
How much strength is lost with core removal???
By Jacob in forum Fiberglass and Composites DiscussionReplies: 20Last Post: 01-27-2010, 12:12 AM -
1971 Allison 15R Core is out
By dirtjumper101 in forum Fiberglass and Composites DiscussionReplies: 92Last Post: 10-01-2009, 02:56 PM -
core replacement 15 Allison
By dirtjumper101 in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 06-24-2008, 05:43 PM
