Results 16 to 30 of 43
Thread: J Class records
03-15-2017, 11:01 AM #165000 RPM
- Aug 2011
- Antioch, il
- 251
- 37
- 15
- 108
03-15-2017, 11:04 AM #175000 RPM
- Aug 2011
- Antioch, il
- 251
- 37
- 15
- 108
03-15-2017, 12:36 PM #18Junior Member
- Jan 2017
- Alabama
- 18
- 28
David Lee set the NOA sport J record at 104+ in the late 70's. Shorter distance than kilo and the xs lower unit with lwp made it possible to run over 100. He also set the APBA kilo record at 96+ before the lwp unit became available.
Mark75H liked this post
03-15-2017, 12:50 PM #19
I know it's not a J class(still 100 cubic inches) but I was thinking the Mod 100 record was like 117??
03-15-2017, 02:49 PM #205000 RPM
- Aug 2011
- Antioch, il
- 251
- 37
- 15
- 108
03-15-2017, 03:36 PM #21
i know Terry Leatherby ran an OMC back then . any idea what motor / boat combo he used?
03-15-2017, 05:39 PM #22
[QUOTE=Mark75H;2936819]That record always makes me wonder why would anyone want to put a nosecone on a lower unit proven to run 100+?
With the XS low water pickup the SJ, or JS depending on the year, boats ran with the bullet just skimming the surface.18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
03-15-2017, 07:41 PM #235000 RPM
- Aug 2011
- Antioch, il
- 251
- 37
- 15
- 108
Yes, it was a V4 Johnson KC13R on a boat built by Harold Nauss. Besides building the boat, Harold did all of the motor and propeller work as well.
They swapped powerheads and set the Mod90 record that same day in Kakauna running over 94 mph. That one held up until 1980 when Jimbo beat it with his Mod50 Evinrude/Molinari exceeding 110 mph.
03-16-2017, 09:50 AM #24
03-16-2017, 11:22 AM #257000 RPM
- Dec 2002
- South Florida
- 2,296
- 155
- 542
- 11 Post(s)
The FS class also ran the J class motors. This class had a much higher weight limit, required a co-driver and motor height was limited. The motor height rule kept the lower unit well below the pad on these boats. This resulted in a serious prop "blowout" problem. At Action Marine we built several boats for FS class and Barney and I spent quite a bit of test time trying to solve this problem. Eventually we decided that shoving that big blunt object through the water at the speeds we were getting was just going to generate sudden blowout every once in a while.
I did a couple of races in FS boats as co-driver. I DID NOT LIKE IT!
The Hydrostream Ventura FS boats seemed to have fewer problems in this area than the boats we were building at the time.Last edited by 2us70; 03-16-2017 at 11:26 AM.
03-16-2017, 01:44 PM #26
Wasn't there one of the OPC classes that powertrim wasn't allowed?
DaveW
03-16-2017, 02:36 PM #277000 RPM
- Dec 2002
- South Florida
- 2,296
- 155
- 542
- 11 Post(s)
Originally none of the sport or production classes allowed power trim. The FS class was the first of those classes to permit power trim. The Sport classes were allowing power trim when I last ran in SD but my boat couldn't make use of it.
03-16-2017, 02:58 PM #28
I didn't realize Harold was a jack of that many trades! I know he was involved with the OMC prop division and he actually built the Evinrude X115 I ran on my Hustler tunnel in the early 70's in UI. Is he still around? Funny side story, in 1970 or 71 I was running FG with my 13' Hustler and an 80 Merc and I had hit bottom in one heat...Harold took my prop around the back of my truck and beat it back into shape using my trailer hitch ball and a sledge hammer! He told me to NOT tell anyone who fixed it...LOL
03-16-2017, 05:23 PM #29
Lots of good stuff. Turned into a great thread!
03-16-2017, 09:19 PM #307000 RPM
- Dec 2002
- South Florida
- 2,296
- 155
- 542
- 11 Post(s)
The J classes were the high watermark of consumer production based OPC racing. These classes allowed us to race durable and reliable motors week after week. Motors and parts were readily available and were relatively reasonably priced. These classes had very large boat counts all across the country and at Nationals usually required several elimination heats to get to the finals. As much as I lusted after those speedmaster equipped U class boats my time in the Sport and Production classes is still a highlight of my life.
PWC speed records
By tropegdirb in forum The Scream And Fly LoungeReplies: 2Last Post: 08-17-2009, 09:19 AM -
speed records
By boatermike in forum General Boating DiscussionReplies: 0Last Post: 05-19-2006, 10:09 AM -
Class C & Class D racing....
By Krazy K in forum General Boating DiscussionReplies: 1Last Post: 05-07-2005, 04:23 PM -
World Records?
By WATERWINGS in forum General Boating DiscussionReplies: 8Last Post: 10-26-2002, 09:33 AM -
Some old OPC kilo records
By KG4 in forum Outboard and Racing HistoryReplies: 4Last Post: 05-28-2002, 03:11 PM
