Results 1 to 4 of 4
03-13-2017, 09:51 AM #1
mercury 5.44 HD lower unit speed loss?
even though the 5.44 lower is much stronger then the 4.8 lower what do you guys think is the possible speed loss on a smaller lighter center console with a single motor (24 spectre CC with a 350 verado)? would the 4.8" gearcase be any faster?
03-13-2017, 05:28 PM #2
depends on how deep you run them..... if you can run the bigger case higher maybe it wont slow you down.
physics tell us more wetted surface =more drag.....soooooooo.......there you have it.
03-13-2017, 08:16 PM #3
the pick ups on both gearcases are very similar so I would not think you could run one higher then the other.
03-13-2017, 08:19 PM #4
I read an article on-line that describes the differences between the 2 and it said that above 60 mph the 5.44 starts to really suffer against the 4.8 on a smaller lighter boat and I'm hitting 69mph now.
Speed master lower unit
By jeremyE in forum General Boating DiscussionReplies: 3Last Post: 07-13-2013, 04:14 PM -
lower unit ratio for speed
By long shot in forum Technical DiscussionReplies: 5Last Post: 09-20-2011, 10:06 PM -
Top speed for a stock lower unit?
By 86vintage in forum Technical DiscussionReplies: 21Last Post: 01-03-2007, 12:31 PM -
XR4 Lower Unit and speed
By j_martin in forum Technical DiscussionReplies: 6Last Post: 11-16-2006, 05:27 PM -
New lower gearcase speed loss
By BW23 in forum Technical DiscussionReplies: 6Last Post: 05-03-2004, 10:59 PM
