Results 1 to 15 of 18
    Apr 2016
    Victoria bc canada
    Opinions on older style trim pump for 2.5 merc...pic included
    Got this pump along with a blown motor I bought for parts... wondering if it's worth keeping or should I get rid of it...everything works great, has new solenoids, new trim lines...no leaks etc...would be using it on a 2.5L carbed merc. Thanks.
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 245 hp merc
    Gravenhurst, Ontario.
    What he said.
    those old pumps don't die.....or at least the 2 I've had wouldn't.
    they aren't fast but they last.
  4. Likes Magcat 62 liked this post
    Jul 2012
    Huntington, Texas
    run it till it blows.....
    Quote Originally Posted by Tomanytoys View Post
    1981 Hydrostream Varmint - 1979 Mariner 175
    Jun 2008
    Sardis Lake Oklahoma
    I've used 'em for years! They can be run on 24v to speed'em up and work extremely well if you change the Pump to a Mercruiser pump.
    Motor, bracket, can, etc. will all interchange but you jst need the pump itself!
    Mercruiser Pump + 24v = Rock'n Roll!!!
    WillySteve Hendricks
    20XDC Bullet/Modified Merc 260
    295TF Charger/ProMax 225x-Sold!
    '83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
    '85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
    Freedom 240 DLX Fisher Toon/Merc 115
    10' Cougar Cub/Merc 25HP On The Bottle!
    18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
    Apr 2016
    Victoria bc canada
    Great! Thanks for the input! I'll run it with my set up for now!
    Jul 2012
    Huntington, Texas
    Quote Originally Posted by WillySteve View Post
    Yep, but 24v to the stocker works too! Also flush out the old motor oil and run atf or tractor hydraulic fluid...
  9. #8
    Mar 2010
    houston, tx
    I like aviation hydraulic oil aeroshell 44 is what I use
  11. #10
    Baton Rouge, La
    Motorcycle fork oil. Easy to find and you can get lighter weight than atf. Mike
    Cheaters never Win !!!
  12. #11
    Apr 2016
    Victoria bc canada
    Lighter the oil, quicker the Trim, less resistance?
  13. #12
    Jul 2012
    Huntington, Texas
    That's it!
  14. #13
    Baton Rouge, La
    Yep like nitro said. Very noticeable difference compared to 30weight. Mike.
  15. #14
    Mar 2010
    houston, tx
    Not just oil weight but check viscosity indexes at varying temps too.
    One of the good things about aviation hydro fluid is it is designed not to have as much variation in viscosity index with temp changes as traditional "tractor" hydro fluid.
    Less variation means more consistent trim timing
  16. Likes nitro_rat liked this post
  17. #15
    Baton Rouge, La
    Good point !
