Results 1 to 15 of 53
03-13-2017, 09:10 AM #15000 RPM
- Jul 2012
- wareham MA
- 309
Who has made a light weight floor?
I spoke with someone on here about a floor for my viper, I trust his advice for a solid floor that will stand the test of time, but I had an idea for a lighter weight floor. As many of you know, a viper has a floor about 3 feet wide, with two stringers about a foot apart in the middle. i feel that a balsa core floor, with two layers of glass on each side would suffice for this boat given the short span across the floor from sides to stringers. Has anyone tried to build a light weight floor with balsa core or foam core???
03-13-2017, 09:52 AM #2Member
- Sep 2016
- BFE
- 54
- 17
- 15
Looking forward to the answers you get. This is the only part of my rebuild I haven't decided on yet. I know a lot of decks that are meant to be walked on sailboats are balsa. I'm personally looking at Corelite PET. My Valero floor is a similar size- 2 stringers a foot apart, total floor width about 40"
nitro_rat thanked for this post
03-13-2017, 03:33 PM #3
I have used thermo-lite board made by Space age synthetics. It's over 100% lighter than encapsulated wood come pre sanded and very easy to work with. The only draw backs a price and you can't screw into it. You glass in mounts or use T-nuts with panel bond adhesive. I used panel bond for my seat base, foot throttle and battery tray in drag boat and that's going on 4yrs ago. The price per sheet seems high but when you factor in cost and time of making wood water proof its not that expensive. I also have used it for transom, knees, bulkheads and stringers. Just another option hope it helps.
Ras Livity liked this post
03-13-2017, 07:39 PM #4
I did my HST floor with 1\2" NidaCore. It was 30# lighter than the (4 x 8) plywood I took out, according to my old notes.
Capt.Insane-o liked this post
03-14-2017, 08:31 AM #5Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I used 1/2'' 12# density penske core board with 1 layer of 1.5 oz matt on both sides in my V-King. Very strong and light. If I did it again, I would go the same route. jm2cts
03-14-2017, 11:04 AM #65000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
On my current build, I am using 3/4" laminated Carbon-core honeycomb. It is around 30# per sheet and reasonable for a composite, around $190. I have been using it for stringers and knees. So far my only complaint is that everywhere a solid bond is required, I have been filling the open cells along the edges with putty for an increased bond. I don't know if this is really necessary or not, but it makes me feel better although adding another step. LOL It will not hold screws well, which I knew when I bought it, so good planning is essential. The step to get it to hold screws is easy and simple Also the 3/4" size was chosen simply to standardize material throughout and I needed 3/4" stringers and knees. 1/2" would have been a few pounds lighter and probably been plenty strong enough for decking. I am spanning around 6' or less and supports will be 12" or less.
03-15-2017, 06:04 PM #7
Aaron Wacholtz put a honeycomb floor in his Virage.
I made balsa panels as a floor over my sponsons (you can see the edge next to the side panels) but decided on plywood for the center for the shear.
Ron Pratt
'91 Virage "The LAST Virage" 15" 280
26' Grady White "fish getter"
03-16-2017, 09:06 AM #85000 RPM
- Jul 2012
- wareham MA
- 309
I think I'm going to try the floor built just like the balsa core in the hull, a couple layers on top and bottom. cut to fit, seal the edges real good, glue it down and glass it in all around. ill try to make a box out of my stringers like factory vipers had to glue the center section down.. I am confident that will do the trick.. Seeing how many various ways you all built your boats and you all are happy with the result, I do not see it being a problem.
Thank you guys for you ideas and replies, your experience is much appreciated
03-16-2017, 06:34 PM #9
A couple of layers of glass ?? what kind of glass ?? the glass is whats going to give you the ridged strength and what you choose and how you make it is the key !!
So be more specific as to what you intend to use !!Definitely not WOVEN !!its possibly the worst glass to use in that kind of situation !!! Do you know the reason why ??Last edited by tunnels; 03-16-2017 at 06:37 PM.
03-16-2017, 07:01 PM #10
Diab used to make and still can I suppose a sandwiched foam panel that is fantastic. Strong , super light and will not absorb moisture. It's the best thing ever I have found for panels bulkheads floors and to some extent stringers for our little boats. Incredibly easy to work with too.
speedman79 liked this post
03-16-2017, 07:27 PM #11
Crunch the numbers to make sure it is "lightweight". Put some thought into how you are going to bond the edge of the floor to the hull. Aside from direct impact, sandwich panels often fail at the edge, because of the way they are finished, or bonded to other panels. Consider the weight cost of bonding in different types of panel to the hull. Consider the weight cost of attaching mounting brackets and seats to different construction floor panels.
03-16-2017, 09:51 PM #125000 RPM
- Sep 2011
- Long Island, NY
- 362
- 78
- 13
Use plywood, you'll go thru more money and more hassle to mount your seats when the ply really doesn't weigh much to begin with. The extra resin and glass will add the weight your saving on using balsa.
JMO1976 Hydrostream Viper - 1500 Mercury I6
1985 21' Hustler - 2.4 200 Merc
1990 18' ArrowGlass CC 140 Johnson -SOLD
1987 21' Seebold Eagle 150 Merc
1990 15' Hydrostream Viper 150 Merc - SOLD
1977 16' Checkmate Trimate II 140 Johnson - SOLD
1969 13' Boston Whaler 40hp Merc - SOLD
Drive it like you stole it!
W2F a V-King liked this post
03-16-2017, 10:52 PM #13Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
03-17-2017, 09:07 AM #145000 RPM
- Jul 2012
- wareham MA
- 309
tunnels, im guessing the woven stuff is far less rigid because the strands are pre kinked, which make them softer under compression and tension. I would try some +/- 45 1700 like i did my recore with. its pretty light weight and is super rigid in the hull. I dont see why it wont work in the floor. Im guessing the floor wont see the same abuse as the hull
03-17-2017, 10:09 AM #15Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
It's the windows in the woven glass that let in the moisture. Can't beat matt for sealing things up....1708 would work well too, but is kinda overkill.
One Oldman, W2F a V-King liked this post
Need advice on Putting a floor in a custom Project, light weight as possible.
By TwzteD in forum Fiberglass and Composites DiscussionReplies: 15Last Post: 04-18-2015, 10:39 AM -
Light weight V-8
By SANTAFE in forum General Boating DiscussionReplies: 5Last Post: 02-06-2015, 11:30 AM -
light weight flywheel
By northeastcat in forum Technical DiscussionReplies: 29Last Post: 08-01-2005, 10:27 PM -
Lite Weight Material To Replace False Floor
By liberatorx2 in forum Technical DiscussionReplies: 5Last Post: 09-22-2003, 11:26 AM -
lite weight material to replace false floor
By liberatorx2 in forum Fiberglass and Composites DiscussionReplies: 1Last Post: 09-21-2003, 06:35 AM
