Results 1 to 7 of 7
Thread: Dual Pyros?
    Camden, SC
    Cool Dual Pyros?
    Who makes the best dual pyro setup for outboards? I picked up another 300X and this time I want to keep an eye on the EGTs. Any insight to this will be great and suggestions for sensor locations would be great!!
    Thanks!!
    Sitka, Alaska
    I got mine from Gaffrig. It was difficult finding gauge manufacturers that offered all the gauges I needed. Gaffrig had them all so I went that route. I'm running a 2.5 so can't help with probe location.
    Ron Pratt
    '91 Virage "The LAST Virage" 15" 280
    26' Grady White "fish getter"
  3. Thanks Tango thanked for this post
    Likes Tango liked this post
    Shawano,WI
    This is a nice set up, just put it on my STV with a 2.5 but haven't run it yet. These work good on snowmobiles. I'm not sure if the 3L exhaust cover bolts are the same as a 2.5 though???
    http://www.exhaustgas.com/ProductDet...pID=&BasketID=
ID:	369692   Click image for larger version.
  5. Likes FAST RALLY SPORT liked this post
    Sep 2015
    ∀ʇOsƎuNᴉW
    Quote Originally Posted by PaulR View Post
    I like the two screws holding on the steering wheel.
    Shawano,WI
    How about that invisible nut holding on the hub!!!
    KOSO makes the best out there IMO I have one on my Drag boat. Reads both banks. It can be programmed for max EGT. If a bank exceeds the max EGT programmed it starts flashing Bright RED. It has a Recall and reset. IMO spend the Xtra $$ and buy the Real Time Exact read Probes. There is no Lag time at all.
  9. Likes W2F a V-King liked this post
    Nov 2013
    Kissimmee FL
    http://www.auberins.com/index.php?ma...roducts_id=504
    I mounted two of this type in the dash.
  1. Mercury Tech: EGT Pyros
    By Go Time in forum Technical Discussion
    Last Post: 08-31-2015, 06:31 PM
  2. Mercury Tech: pyros temps for 3.0-3.3
    By R.grover in forum Technical Discussion
    Last Post: 09-12-2011, 03:29 PM
  3. Pyros
    By Skirace87 in forum Technical Discussion
    Last Post: 11-17-2007, 08:03 PM
  4. Dual pyros on 300PM's
    By Liquid Force in forum Technical Discussion
    Last Post: 05-22-2006, 08:31 AM
