Results 1 to 1 of 1
03-06-2017, 08:36 PM #1
2000+ optimax 3.0L bleed lines and check valve routing
didnt even think about it, but recieved a new powerhead WITHOUT ANY FITTINGS and didnt document how the bleed lines were routed and what ports were blocked and what had fittings with check valves or open fittings... ANYONE have the bleed line routing and layout for a 2000 or newer optimax 225???
Mercury Tech: 1979 150hp bleed lines and check valve flow directions ?
By HarleyPHD in forum Technical DiscussionReplies: 4Last Post: 08-23-2014, 09:42 PM -
Best tubing for bleed lines/small fuel lines 2.4 MERC
By rujr in forum Technical DiscussionReplies: 25Last Post: 07-10-2013, 10:26 AM -
Mercury Tech: Bleed line routing...help!!!
By motorheadbishop in forum Technical DiscussionReplies: 5Last Post: 04-15-2009, 10:31 PM -
Merc bleed line routing?
By CDave in forum Technical DiscussionReplies: 4Last Post: 06-15-2004, 04:12 PM -
Colored bleed lines and water dump lines
By DaveR in forum General Boating DiscussionReplies: 23Last Post: 02-20-2003, 08:52 PM
