Results 31 to 34 of 34
Thread: Making a drag plate
03-18-2017, 05:05 PM #317000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
the down bend at the end is for not. you trim the motor down [in] to do the same thing. the trim tap will get in the way of some prop. get rid of it and use a skeg tab.
03-18-2017, 06:25 PM #32
I agree those tabs do get in the way, but they do work on a buried prop set up.
I have not thought about a skeg tab, do they work as well or better than the normal ones if a prop is not surfacing ?
03-25-2017, 07:59 PM #33Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
03-25-2017, 08:04 PM #34Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
Krazymaan liked this post
drag plate
By eli in forum General Boating DiscussionReplies: 0Last Post: 12-05-2016, 11:59 PM -
Drag plate ?
By phillnjack in forum Props, Setup, and RiggingReplies: 15Last Post: 11-05-2016, 07:34 PM -
Making a 6" jack plate into a 10"?
By sharkcrazy in forum Props, Setup, and RiggingReplies: 5Last Post: 02-22-2008, 10:57 PM -
OMC Drag plate
By Laker in forum Technical DiscussionReplies: 13Last Post: 06-06-2002, 09:18 PM
