Page 7 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 91 to 105 of 176
  1. #91
    Dec 2011
    Ludington michigan,on the shore
ID:	369914Well, sixteen days and we're ready to start to assemble.Did the last of the gel coat this morning.Had some left so did the seat frames in resin then topped with gel.Almost seems a shame to cover the nice new floor with carpet,but WTH! Not going to put the back seats in now,just going to keep it clean and simple. A couple shots of the transom,before and after. Ten plys vs twenty five.Click image for larger version.
ID:	369912Click image for larger version.
  2. #92
    Great work! Ya have the same rear seats as mine? Side by side, facing each other? Remember just 2 floor clips (each) to hook in mine, but seldom in. It was a bitch getting on plane even tucked in. Surface prop, little trim to work with, running a 2B cupped 14x28 SS meant "everybody up on front 'till it hooks up, and "sit down, shut up, and hold on!. If more ..or fatter?, 14x19 bronze 3 B on, the ski prop. Best boat of maybe 2 ever owned..(Damn right the other was a ALLISON!)
  3. #93
    Dec 2011
    Finished the last of the syrup today.Have been chipping away at the boat,seats are done,carpet done,deck is on,tank pumps battery and most rigging done.Going to try and hang it on the scale,just curious as to its weight.Click image for larger version.
ID:	370731Click image for larger version.
  4. Likes Capt.Insane-o, FMP liked this post
  5. #94
    Jul 2007
    Have lived and worked in New Zealand ,Tahiti,Australia,Japan , south Korea, And now Suzhou in China
    Keep it dry !
    Quote Originally Posted by outasite View Post
    With all that carpet every where get a dehumidifier and a close fitting cover and every time you use your boat place the dehumidifier inside and cover the boat and see how much moisture it sucks out YOU WILL BE AMAZED ! IT KEEPS THE WHOLE BOAT DRY !!
  6. #95
    Don't worry it weight ..(but curious too?), but as NEWMAN would say?..."work it"?
  7. #96
    The floor is glassed and sealed, even if it gets wet a day in the sun and it's dry. Air flow under the cover is important even when it's in the garage . We leave boats in the water for months, covered when not being used, just let it breath. Dehumidifier, not once have I seen that. Couple times a season with the Hoover to keep the sand out .
  8. #97
    Jul 2007
    It dry's the whole inside of the boat As in every where, totally !!No condensation ,no moisture, timber, glass, and specially the carpet ,No musty smells. Its amazing what it does for Cabin boats Most guys cant believe the amount of moisture that comes out !! air flow does little to dry anything !! In salt water the air flow actually make condensation with the salt crystals !! where as dehumidifier takes away and completely dries EVERYTHING ,EVERY WHERE, TOTALLY !!
  9. #98
    Please post a pic of her all rigged and looking sharp!
  10. #99
    Jul 2007
    If we put the boat inside a sealed air tight garage then a dehumidifier would be able to keep up. In a regular garage or boat house, wouldn't make a bit of difference.
    YOU ONLY NEED TO DRY THE INSIDE OF THE BOAT THATS ALL !!tHE AMOUNT OF cubic feet of AIR IN A GARAGE OR BOAT HOUSE IS HUGE !! A close fitting plastic cover is all that's required and the dehumidifier inside under the cover !.
    Its how I have dried natural native timbers for wooden floors for years and works a treat every time !.
  11. #100
    Jul 2007
    No doubt that would work and some one with a swampefd interior who has run out of summer sun could benefit.
    All the Air we breath has humidity !! That moisture is every where as in EVERYWHERE !! A DEHUMIDIFYER WILL LOWER THAT HUMIDITY to as low as you want and take that moisture out OF THE AIR !
    WITH DRY AIR everything else dries as well and it sucks moisture out of everything totally !
    We used this to dry cloths HANGING UP in our laundry and to keep the back side rooms of our house dry that never got sun !.
    When I laid wooden floors id lay a big plastic sheet on the floor first and stack and fillet the timber on top and seal the timber inside the plastic and place a dehumidifier inside the bag and DRY TIMBER !! Only ever took just a matter of days till it was completely dry ready to be laid !NO CLAMPING REQUIRED !! then the timber would RE-acclimatize and re absorb humidity to it surroundings and swell and tighten the gaps 100% closed !NO HEAT REQUIRED AT ANY TIME
  12. #101
    Jul 2007
    Dehumidifyers are needed !!
    Yup, familiar with laundry and the saturation point of air with respect to temp. No argument
    THIS JUST ONE OF ANY !
    http://www.air-n-water.com/how-dehumidifiers-work.htm
  13. #102
    Jul 2007
    I'm Canadian, not ignorant. Lol
    Never implied you were !! but there are some readers don't believe what others try to tell them .
    All my information comes from my own practical experience's learned over many years and things that work well and keep on working !
  14. #103
    Aaaaaannnnnnnyway you thread crappers.......... hey Bob where you get the fuel tank?
  15. #104
    I'm waiting to hear and see more of the work, think the boat is super.
  16. #105
    Jul 2007
    Quote Originally Posted by Robby321 View Post
    Tunnels? Come on dude. Were not talking house flooring, enclosed cabin boats that sit in the water whatever. And cabin boats in salt..(like a lotta salt midwest)..had a 26 footer Cabin in slip salt all summer. Remember I'm PNW, in salt too. Never a prob, and winter yanked for the damn rainy season! Simple covered with air flow in and out. Have a private HOA 110 slip marina, and trailer boats out the rainy, but many simple slipped year round, rag boats, big cruisers. No shore power either. More concern the damn birds crapping on it, taking over.
    Also the Switzer his is a 76. As has same but a 74. His boat needed a transom as hanging more HP than the Swit boys intended. Built for the new IL XS1500. Its 41 YEARS old boat and rest fine after all the decades. Bet as top popped, total sealed (again), we will ALL be dead before it "rots out!
    On a dehumidifier? Ever try doing something inside? With normal air flow..(house, boat, etc) and then out side and see what ya get water? Probably the same. All it does is suck moisture out the air. Unless a vacuum enclosed room. Hmm..why do the make HUMIDIFIERS?
    Its a damn boat..USE IT! Its GONNA GET WET! Just need air exchange. Not a prob me 60 years...(JMHO..don't take life so serious..use it..its all ya got)..
    You need to understand what simply drying the air can do and will do specially in enclosed spaces takes the moisture out of everything nothing excluded will and can dry the bilge end to end including the cushions and bedding , even cloths hanging up inside a shut up cruiser and does no harm !! get rid of musty smells and mildew and mold !
  1. Transom skin cut help and transom rebuild
    By SSweet87 in forum Fiberglass and Composites Discussion
    Last Post: 10-12-2008, 12:51 PM
  2. need help transom rebuild
    By nuddybuddy in forum General Boating Discussion
    Last Post: 10-02-2007, 06:48 PM
  3. Transom rebuild
    By cltch in forum Fiberglass and Composites Discussion
    Last Post: 12-05-2006, 06:18 PM
  4. Transom Rebuild
    By Chummy in forum General Boating Discussion
    Last Post: 01-02-2003, 06:08 AM
  5. transom rebuild
    By streaming demon in forum Technical Discussion
    Last Post: 12-17-2001, 05:08 PM
