Results 1 to 15 of 16
Thread: Lower unit Painting
03-01-2017, 11:25 PM #15000 RPM
- Sep 2008
- Delaware River,NJ
- 354
Lower unit Painting
I have removed all the paint and will use an etching wash before painting but I'm getting conflicting methods of painting.
I'm going to use Interprotect 2 part epoxy and they say I can just put that on right after sanding.
But their directions also showed using their zinc chromate paint first, which they no longer manufacturer.
Should I spray an etching primer first, like Rustoleum Etching Primer or Moeller Zinc Phosphate then epoxy? Moeller doesn't carry the zinc chromate any more.
03-02-2017, 12:30 AM #2Junior Member
- Nov 2014
- Port Royal, pa
- 26
Check napa auto parts I think they may carry it
03-02-2017, 07:24 AM #3
DON"T PAINT IT!!! If the LU is for a "go fast" send it to East Coast Powdercoating (Bud Conner...member S&F) and have him apply the hi-speed SS coating that should be good for at least 1 -2 MPH. Bud is a perfectionest and you will be real glad you did! I don't have any pics but mine is a piece of art! Gary
Dave Strong, Greg G liked this post
03-02-2017, 12:17 PM #4
XstreamVking liked this post
03-02-2017, 12:31 PM #5"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
Dave Strong liked this post
03-03-2017, 08:10 AM #6Screaming And Flying!
- Jul 2004
- Connecticut
- 6,007
- 464
- 168
- 910
- 951
03-03-2017, 11:28 AM #7
02-01-2018, 08:02 AM #8
I'm getting ready to strip my clamp and can. I have a hand blaster, but unsure of what media to use to blast it.
02-01-2018, 08:27 PM #9
Glass bead (fine)
02-02-2018, 07:43 AM #10
Thanks, I'll give it a try.
02-12-2018, 02:07 PM #11
I see you say glass bead, but at what sort of pressure ?
I have a big tank I made myself (50 gallon drum ) and can get big stuff in there. I will be stripping down a lower unit too.
I have very fine glass beads , I didn't get crushed glass as heard thats not so good. hardly any price difference too.
being in a tank I get to keep the beads to re-use.
02-12-2018, 07:52 PM #12"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
phillnjack liked this post
02-13-2018, 10:48 AM #13
sounds good.
I will give that a go soon, need it to stop raining so I can get the electric out to the garage.
I can fit a lower unit in here now as have a hole in the door to poke the drive shaft through.
to stop dust getting out I put a bit of inner tube from a bike on the door where shaft goes through a hole..
I have found some props are hard to blast, the Teflon coated are the worse.
02-13-2018, 06:49 PM #14
I like that ...I just bend over the trash can with my arms on each side of a peice of plexiglass to look thru.
Gary"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
03-13-2018, 03:54 PM #155000 RPM
- Melbourne, Florida
- 645
- 13
anyone have a number for east coast powdercoating
Painting lower unit
By hydrohellion in forum Appearance ModsReplies: 2Last Post: 06-05-2012, 12:27 AM -
Painting lower unit.
By Mr. Demeanor in forum General Boating DiscussionReplies: 27Last Post: 11-19-2011, 01:52 AM -
painting midsection and lower unit
By cocacola in forum Appearance ModsReplies: 11Last Post: 08-06-2007, 08:42 AM -
Painting your lower unit---- DON'T
By Techno in forum Appearance ModsReplies: 2Last Post: 10-03-2003, 02:15 PM -
Painting lower unit?
By pyro in forum Technical DiscussionReplies: 5Last Post: 07-14-2003, 09:44 AM
