Results 1 to 15 of 65
02-25-2017, 12:28 PM #1
Need help with 260 piston removal
Here comes dumbest question ever. I was checking piston ring clearance by pushing #3 piston in the cylinder backwards. The piston ring slipped passed the bottom end of the sleeve and the ring expanded. How the hell do I get the piston back out?
02-25-2017, 12:36 PM #2
go in from crank side and use your fingers to squeeze the rings back in.
its what god gave you fingers for.
02-25-2017, 12:55 PM #31980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
brussrude liked this post
02-25-2017, 12:57 PM #41980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
02-25-2017, 01:01 PM #5
long dentist pick????
02-25-2017, 01:25 PM #6
We must be related lol. Some type of pick I guess. Good luck cuz
02-25-2017, 02:08 PM #7
I remember awhile back someone asking the same question, he had the pistons just barely in the bore and his young kid pushed them to the bottom, don't remember the outcome.
is gone
02-25-2017, 02:13 PM #8
Kneeling in a pile of rice maybe?????
WillySteve liked this post
02-25-2017, 02:39 PM #9Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Can you slip a looped end of braided fishing line over the end of the ring and slide it around midway so you can pull it out or try to rotate the piston with the ring looped pulling the ring off as you turn ?
Dave Strong, WillySteve liked this post
02-25-2017, 03:01 PM #10Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Oh , the piston. Oops you better show us all with a pic. OK got it lol. I'll wait till you get it out before I ask.
02-25-2017, 03:30 PM #11
I know a guy that did that.... He had to mill the piston out. Sorry, that sucks
2023 TUFF 25
02-25-2017, 06:24 PM #12
heat the block to 500 degrees for 1 hour and pull the sleeve out with the piston!!!
death is certain; life is not
02-25-2017, 06:36 PM #13Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
No kidding! If he can't break the ring?
02-25-2017, 07:50 PM #14
Is this being done with the crank in ?
put a pic up of the crank in the block and show us why you cant get it back up.
if its past the bottom of the sleeve then take the ring off, use a feeler gauge to lip round the ring.
easy fix.Last edited by phillnjack; 02-25-2017 at 07:52 PM.
02-25-2017, 08:00 PM #15Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Clear as mothers milk
OMC Tech: Piston Removal V8
By kimswang in forum Technical DiscussionReplies: 15Last Post: 03-31-2009, 04:25 PM -
2.4 piston removal
By lakerider8 in forum Technical DiscussionReplies: 8Last Post: 01-08-2007, 02:18 PM -
Piston pin removal
By Scott in MN in forum Technical DiscussionReplies: 3Last Post: 12-16-2006, 08:59 PM -
Piston pin C-Clip removal?
By mxz in forum Technical DiscussionReplies: 7Last Post: 05-04-2004, 07:41 AM -
Piston Ring removal?
By mxz in forum Technical DiscussionReplies: 3Last Post: 11-19-2003, 01:45 PM
