Results 1 to 9 of 9
Thread: poppet bypass
    Feb 2016
    South Florida
    poppet bypass
    im interested in knowing more about the poppet bypass, ive been searching before I make a post but have not had much luck finding any detail on how to bypass and why to bypass, is there a good thread with the steps to do this mod?
    Quote Originally Posted by Nicklab View Post
    You'll not find a thread on it because the poppet should never be bypassed. It is an essential component to the cooling system.
  3. Likes rock, Dave Strong liked this post
    Mar 2010
    houston, tx
    If you have a 2 piece adapter plate leave it.
    Sep 2015
    Twin Cities, Minnesota
    You need to post what motor you have and if you have a 1 piece or 2 piece adapter between the motor and midsection. Telling us what boat you have isn't necessary but we all like to know.
    Feb 2016
    South Florida
    boat is a 17' lake and bay
    engine is a 200hp carb I think 1997, im not sure if 2.0 2.4 or 2.5 (how can I tell?)
    the poppet has a 2 piece housing, and im in the process of sending my gearcase to bobs, and I hear that the poppet doesn't like the higher water pressure associated with the nose cone low water pickup. if that setup is going to run fine, then im happy to leave it alone
    No idea where this nonsense gets started, add the cone and run it. You'll be fine. There are several thousand other boats running around with nosecones/Sporties and working poppets.
    Aug 2015
    NE Tennessee
    97 200 is a 2.5, or "should be", unless the power head has been changed.
    Serial number or a picture would help ID what you have.
  9. #8
    Feb 2016
    South Florida
    powerhead is sitting on a 135 mid
    OG549962 is the freeze plug stamp
  10. #9
    Feb 2016
    South Florida
    Pic
    Attached Thumbnails Attached Thumbnails 20160711_193121.jpg   20160711_193055.jpg
  1. Mercury Tech: Poppet Valve kit - which one for this poppet?
    By gmacrae in forum Technical Discussion
    Last Post: 10-07-2014, 04:53 PM
  2. **Poppet Or Drop It** ??? (poppet valves)
    By mercpunk in forum Technical Discussion
    Last Post: 05-16-2007, 07:37 AM
  3. '89 Merc 100HP Oil Injection - To bypass or not to bypass ?
    By MartyTn in forum Technical Discussion
    Last Post: 10-30-2002, 12:58 PM
