Results 16 to 26 of 26
02-24-2017, 09:12 PM #16
The timing advance will not go past the timing stop....... unless the timing stop came loose, there was no problem with the timing per-say.
02-24-2017, 09:14 PM #17
02-24-2017, 09:27 PM #185000 RPM
- Nov 2008
- martinsburg, wv
- 398
Heres a better picture after cleaning the junk out of the ring grooves. I wonder if they stuck open thermostat caused the ring to carbon up and break on the port? Seems like a long shot BOTH pistons would go in the same exact place though. The pins are not as high as the bottom rings, but they are definitely there.
02-25-2017, 12:06 AM #19
Nah, something came loose and went through that side. I have seen reed or carb butterfly screws do that or possibly something loose under the hood got sucked into the engine. Carbed rings won't do that. how do the reed valves look?
02-25-2017, 08:21 AM #20
Any marikings on the inside of the pistons as to who they are made by, doesnt look like wiseco by the .030 marks, one pic shows ring wear pattern riding only on outer edge of land/ funky wear pattern on lower edge of pistons , possibly from cheap pistons / improper bore job like racer said, maybe not cut at the bottom properly (funky wear pattern ) , port not chamfered properly as rings wore and maybe with a little help from carbon jacking got more knife edged caught and tore up. Delectors are not melted. Dave
02-25-2017, 09:27 AM #21
Or as was said above could have had something go thru it, usually one of the ports will have the fist sign of the initial screw or what ever got caught mark on it. I know most don't do much chamfering on cross flow ports but i had a 140 v4 back in the 80s with high ringers, got pistons for free no body wanted them, all ports were radiused by hand and it ran for ever never had a ring fail. dave
02-25-2017, 12:09 PM #22Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Maybe the end gap wasn't checked and it bound up. Who knows what the builder did, can you get .040 rings for these pistons? Maybe he .010 upped these two rings and didn't fit them correctly?
02-26-2017, 10:41 AM #23Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Looking at those photos looks like pin is sunk enough to allow ring to pass over. If the ring was broken most likely the issue. Not from timing as no sign of detonation
pointer liked this post
02-26-2017, 02:09 PM #24Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I see no pins, just holes?
02-26-2017, 03:21 PM #25
02-26-2017, 03:30 PM #26Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Look at what I just picked up !
By outlaw 10.5 in forum General Boating DiscussionReplies: 20Last Post: 06-28-2016, 06:52 PM -
Eliminator Daytona 22 catamaran SALE PRICE 8900! cheap cheap
By Ferrari Boat in forum Hulls larger than 20'Replies: 20Last Post: 05-22-2015, 09:19 AM -
picked up a new toy!!!
By gettinwet in forum General Boating DiscussionReplies: 4Last Post: 08-18-2009, 05:20 PM
