Results 1 to 15 of 26
02-24-2017, 01:20 AM #15000 RPM
- Nov 2008
- martinsburg, wv
- 398
02-24-2017, 07:16 AM #2
I have a 84 OMC 140 cross flow that I have no idea how many hrs are on it. It caught a ring on # 3 cyl and hammered the piston and head. I was told that the performance V4s have a tendicy to do this with a lot of time on them. Your mota having 2 cyls with the same problem and a broken timing connection... you may have found the problem. I would check the carb bowls and jets also. Gary
02-24-2017, 07:56 AM #3
That to me looks like over heat for sure, i have a 3 cylinder that has a piston just like that for damage.
if you only have the omc temp sender that is on a buzzer they are useless.
best to have a gauge for each bank so you know what is happening.
02-24-2017, 10:15 AM #45000 RPM
- Nov 2008
- martinsburg, wv
- 398
Not sure if this is relevant information but after further tear down the thermostat on the two blown cylinder side is stuck open
02-24-2017, 11:09 AM #55000 RPM
- Nov 2008
- martinsburg, wv
- 398
02-24-2017, 01:38 PM #6
I would sooner say over heated rather than too cold.
were the little rubber diverters in the waterways in the right places ?
02-24-2017, 01:39 PM #75000 RPM
- Nov 2008
- martinsburg, wv
- 398
02-24-2017, 04:17 PM #8
from what I can see the water passage looks to be very very clean, like a drop or two of boiling water has gone through it ?
Hope you manage to get it re-built
02-24-2017, 06:30 PM #9Scream And Fly VIP
- May 2001
- Hickory NC
- 5,579
- 18
- 248
- 203
- 462
- 4 Post(s)
Does not appear to be heat related. Check the ring locating pin. Since it is .030 over may not have had proper clearance.
pointer liked this post
02-24-2017, 06:43 PM #10"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
02-24-2017, 06:45 PM #11
02-24-2017, 06:46 PM #12
How do the reeds look? any broken? could have eaten a reed or two
02-24-2017, 06:47 PM #13
02-24-2017, 07:01 PM #145000 RPM
- Nov 2008
- martinsburg, wv
- 398
02-24-2017, 09:10 PM #15
I see the locator pins in the bottom rings, but what about the top rings that caught the port?
Look at what I just picked up !
By outlaw 10.5 in forum General Boating DiscussionReplies: 20Last Post: 06-28-2016, 06:52 PM -
Eliminator Daytona 22 catamaran SALE PRICE 8900! cheap cheap
By Ferrari Boat in forum Hulls larger than 20'Replies: 20Last Post: 05-22-2015, 09:19 AM -
picked up a new toy!!!
By gettinwet in forum General Boating DiscussionReplies: 4Last Post: 08-18-2009, 05:20 PM
