Results 1 to 2 of 2
02-22-2017, 05:00 PM #1Member
- Mar 2016
- N/A
- 64
- 7
Mercury 2.4 Crankshaft sealing rings
Hi there,
Im in the process of rebuilding my 2.4 v6 mercury. I have noticed that the 3rd crankshaft sealing ring is missing, i understand that this is down the where the oil drive gear should be, my oil pump system has been removed so i was going to fill in the gap where the drive gear should go to even out the compression in that chamber. Once this is done will i need to install a sealing ring to the empty slot on the crank or is it best left off? I was going to fill and shape the drive gear hole with epoxy and match it to the other chambers.
Cheers
02-22-2017, 05:17 PM #2
It is common to leave off the rings above the mains. Little bit of gravity action.
RockTeam Junk
mercury crankshaft sealing rings
By davemvegas in forum Technical DiscussionReplies: 10Last Post: 12-18-2011, 10:28 AM -
By hydrostream1 in forum Technical DiscussionReplies: 4Last Post: 06-03-2007, 12:47 PM -
Merc crankshaft sealing rings?
By gambler183gt in forum Technical DiscussionReplies: 15Last Post: 11-22-2004, 11:03 AM -
By TB21 in forum Technical DiscussionReplies: 3Last Post: 12-13-2001, 09:02 PM
