Results 1 to 4 of 4
02-21-2017, 05:43 PM #1
Setting hi speed timing 2.4 litre 220 laser motor
Having problems with the hi speed.Batteries fully charged idle cranking ecu diconnected, fuel pump power disconnected, spark plugs removed and all 6 cylinder spark plug leads grounded. I get 8 degrees. When I check full throttle the timing light is not steady blinking. the timing appears to be jumping around from 19 degrees to 26 degrees. I can not get a good reading. Problem on water will not get up on plane. Appears to run great on hose. All six plugs are firing and three coil packs firing.
Thanks
02-21-2017, 07:54 PM #2
Possibly a bad high side winding in stator. Cdi has the pinpoint test online on how to test.
02-22-2017, 12:49 PM #3
Idle stabilizer disconnected? harness cover for trigger hard and not letting advance work smoothly?
02-23-2017, 12:12 PM #4
I'll check that out Dave, I don't remember if I had the idle stabilizer disconnected, trigger was fine and not binding. I'll check it again this weekend and let you know guy. Thanks.
Setting timing using a 16 amp lightweight flywheel with no timing marks
By jdewaard in forum Technical DiscussionReplies: 19Last Post: 09-09-2015, 07:56 PM -
setting timing 2.4
By Jerry Millington in forum Technical DiscussionReplies: 12Last Post: 08-04-2004, 02:17 PM -
Setting Timing On A 2.4
By awjens in forum Technical DiscussionReplies: 2Last Post: 07-03-2004, 08:55 AM
