Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
    Sep 2015
    Twin Cities, Minnesota
    When I was out in mine at about 90ish. which i never got higher than super low 100's out of being a chicken. There is a point in which the bow is aiming about 5 degrees up. The closer to 100 I get, the bow comes up even higher probably under 10 degrees up. Which is perfectly normal and its what its suppose to do when packing air under there lifting the boat off the water. But all you can think of is am I going to blow over and then I slow down. It feels like a dragster riding a wheelie down the track accelerating faster and faster. Maybe this summer I'll go faster, maybe not.
  2. #17
    Sep 2015
    Around 2:10 We were going around 100. I had Me, My Son and My Nephew in the boat. But it sure was fun. Of course you can't see much of my boat because we were doing the filming.
  3. #18
    Dec 2016
    MS Gulf Coast
    Quote Originally Posted by Krazymaan View Post
    What are the specs on your setup ? Prop, setback, engine height ? This is the only close up of mine.
  4. #19
    Sep 2015
    Let's see. My boat is a 1986 so it's a touch different than yours. I have an early 4 hole unmodified CLE, which this boat seems to love. The mid is a production 20" fishing without the drilled cavitation plate. Mid sleeve is removed. Has a solid mount 2 pcs adapter. Forgot what tuner is in it. Has a manual 4" jackplate. It's set up about 1.5 inches up. The prop is some sort of custom Yamaha drag prop, pitch unknown, probably low 30s. This property hooks and books. Made by DAH for this boat. Hitting 100 plus at just under 6500 with a minimum of 1500 rpms to spare. And that was with 3 adults and 25 gallons of fuel. So I can testify that you can make the right boat with the right regular parts haul ass. Just ask Tabera Racing, they built it.
  5. #20
    Sep 2015
    Now if you ask me what's my next setup that's a whole different story.
  6. #21
    Dec 2016
    MS Gulf Coast
    Tach & trim indicater not working but my son and I hit 97 gps with stock 225 6" setback 1" above and a Herring bravo 14.5x30 4 blade. Going to mount engine on transom and see what it does. Ordered new guages last night. Going to try out a couple of my sons props to see what it likes.
  1. looking for a member
    By fkboatman in forum The Scream And Fly Lounge
    Last Post: 04-04-2010, 08:49 PM
  2. hi i'm a new member
    By dzalj1 in forum Technical Discussion
    Last Post: 05-31-2007, 08:00 PM
  3. New Member
    By 519NASCAR in forum The Scream And Fly Lounge
    Last Post: 04-07-2007, 11:50 AM
  4. New member here
    By Rob'Z in forum General Boating Discussion
    Last Post: 10-28-2005, 11:07 PM
  5. Welcome to a new member
    By Baja18 in forum The Scream And Fly Lounge
    Last Post: 06-14-2004, 12:38 PM
