Results 1 to 15 of 17
Thread: help ID 2.5 FrankenMerc
02-19-2017, 12:26 PM #16000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
can't find a serial number,but has 225/260 C3 heads with dowel pins,steel bore,(put a magnet to bore and pulled it out of my hand),has been converted to carb,with WH22's,has a small hole in front half,looks like it spit a piston ring,makes sense to call it a promax,except for the fact the block appears to have a date code stamp of 03 08 90.? haven't had time to tear it down further,but has 3.5" bore also.
02-19-2017, 12:29 PM #26000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
02-19-2017, 12:33 PM #36000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
02-19-2017, 12:35 PM #46000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
02-19-2017, 02:08 PM #56000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
pretty sure it's a promax frt. 1/2,has an oil injection port,with a block off plate,whereas the 245/260 was just a machined boss,and has 7 petal reeds,
02-19-2017, 02:20 PM #6
That's some serious frankin' mercin' going on I think?
wasnt 91 first year for 2.5?
02-19-2017, 02:40 PM #76000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
yes,was no promax yet,so,don't know what it is,
02-19-2017, 02:44 PM #8
My first guess would have been 200 promax with a 2.4 flywheel on it but the date is throwing that off.
I have no idea
02-19-2017, 03:24 PM #96000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
02-20-2017, 12:32 PM #10
The three welded up holes on the sides of the cylinders would have been where the rubber bleed off tubes went.
02-27-2017, 12:07 AM #11
02-27-2017, 10:15 AM #12
02-27-2017, 10:42 AM #13
not very often but date stamps have been wrong... ask Bobby!...... 1st gen block with fat block build date!.. once stamped, no goin' back.. can't be surprised with anything merc builds at anytime!
02-27-2017, 11:00 AM #14
What are the three drilled and tapped bosses for on the side and what is the big boss facing upwards for. Every photo i ever see, nothing is ever attached to them. Is that a 2.5 thing or can 2.4's have them too? I've seen 2.4's for sale with those but none of my 2.4's have any of those drilled bosses/pegs/posts, whatever you call them.
02-27-2017, 11:08 AM #15
they are for additional boxes that are use on various motors.. ie: idle stab., oiler, knock sensor etc. early (analog) efi hot rods for tpi..... jus a lotta different things... yours was way before all that stuff came out.....
jus take a look at bone stock power heads and you'll see.............Last edited by tlwjkw; 02-27-2017 at 11:11 AM.
Mercury Tech: Frankenmerc ADI Conversion
By poppop545 in forum Technical DiscussionReplies: 6Last Post: 04-03-2014, 12:12 AM -
Mercury Tech: The 2010 FrankenMerc Project is done and it's Alive -
By sschefer in forum Technical DiscussionReplies: 2Last Post: 07-11-2010, 11:18 AM -
FrankenMerc: Trim Differences and Questions?
By rbaklini in forum Technical DiscussionReplies: 5Last Post: 04-02-2009, 08:08 AM
