Results 1 to 15 of 17
Thread: would you use this?
02-14-2017, 08:40 AM #1
would you use this?
Would you use this in a non-high performance application?
It is perfectly straight.death is certain; life is not
Glasstream15 liked this post
02-14-2017, 09:18 AM #2
With a prop I didn't care much about maybe... I've seen em twisted but never like that without being crooked!
02-14-2017, 09:28 AM #3Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7150
- 3 Post(s)
I agree, with BadAction-It always makes thing worse when you have to be towed in after losing a prop and then knowing that it could have all been avoided. Why take the risk? correct it while you can and avoid the hassle.
1BadAction liked this post
02-14-2017, 04:17 PM #4
Disaster looking for a place to happen.
I carry a gun because a cop won't fit in my pocket.
1987 Glasstream 15V
1986 Mariner "Tower of Power" 115
02-14-2017, 05:53 PM #5
I noticed the post ask "would ya" not should ya! You no you want to,like Bad said,old prop and let it rip.Just let us know how long she goes!
02-14-2017, 05:57 PM #6Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I have pulled many props to find the splines twisted when doing service. Made the owners put their props back on themselves if not replaced. It might last for years, or minutes...
RSWORDS liked this post
02-14-2017, 08:03 PM #7
As Stated^^^
I personally have twisted 3 from running N2o. They've always been straight but twisted. I've ran them even after seeing the twist and never had one break....On the other hand I've snapped one clean off by hitting a stump!
Personally, I WOULDN'T RUN ONE WITH AN EXPENSIVE PROP until it was replaced and also consider that if it let go at a high RPM, it could pass you by way of your boat hull....or somebody else!!Last edited by WillySteve; 02-24-2017 at 10:43 AM.
WillySteve Hendricks
20XDC Bullet/Modified Merc 260
295TF Charger/ProMax 225x-Sold!
'83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
'85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
Freedom 240 DLX Fisher Toon/Merc 115
10' Cougar Cub/Merc 25HP On The Bottle!
18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
02-14-2017, 09:34 PM #8
No..it's to easy to swap in a new shaft. Or a good used one.
WillySteve liked this post
02-15-2017, 11:55 AM #9
The hell with losing a prop, where would it go/what or who could it hit after it flies off!?!?!? Losing a prop would suck, injuring or possibly killing someone.......replace it!
AIRWALK
gettin' old ain't for sissies
02-21-2017, 02:03 PM #10Member
- Aug 2015
- Cass County Mo.
- 39
Make sure the trolling motor batteries are fully charged.
Your gonna need em.
Chris
02-22-2017, 08:17 AM #115000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
Looks like a 'run it till she blows' situation if you don't mind being stranded, losing the prop, and possibly damaging the lower.
02-22-2017, 04:03 PM #12
Well the best way to know if it is going to be ok is to get is x-rayed.
so just take all the trouble and get the propeller shaft out the gearbox get it examined then buy all new seals and put it back on and be happy you save a small amount of money.
Or just look around for a good used one or bargain new one then fit it with nice new seals and play it safe.
I have seen shafts with twists like this last for over 20 years, but also seen some not this bad break the next time out.
when you do change it, keep that one and use it to make yourself a nice prop holder in the garage.
02-25-2017, 06:26 PM #13
I have never seen one twist! I am lucky I guess. What causes it?
10-12-2019, 08:14 AM #14Member
- Oct 2019
- Clearwater, Fl.
- 61
- 10
Ha ... When she goes ... wonder what the tach will say!
10-12-2019, 09:21 PM #15
Ya I no this is old but I had a 150 I run forn3 yrs looked exactly same , had very little $ n motor and prop. Wasnt to concerned at the time as long the prop went on. Never broke ,sold motor , then he sold it with same lower. Sure it needed b fixed but it lasted a very very long time and not sure it ever broke
