Results 16 to 30 of 36
    Apr 2016
    Victoria bc canada
    Quote Originally Posted by 90 5.0 View Post
    On which boat??? LOL
    ive run 260's promax cut like a 260 and 200's on one piece plates In the past. Same situation get gravel up in the passages and flow sucks out the dumps.
    Haha fair enough! Even tho I have visable flow at the top of both heads with the t stats restrictor covers removed, you think I should still remove the heads and diverter plate?
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 245 hp merc
  2. #17
    Mar 2010
    houston, tx
    So no flow with the plates and washers on and lots with them off? Check the plates and the hoses first!!
  3. #18
    Apr 2016
    Victoria bc canada
    I've blown through all the hoses, they're clear, with the covers off I can flick the hose on and see water flowing to the top of the heads, it's almost like there's not enough pressure to blow past the restrictors into the dumps.. or all the water is flowing past and down.. by passing the restrictors, maybe I should take the restrictors out and see if it'll flow out the dumps then..?
  4. #19
    Apr 2016
    Victoria bc canada
    Or just bite the bullet and pull heads and exhaust plate... it's weird I can run the motor with the hose shoved up the water tube and the heads are cold to the touch so water is flowing through the passages...
  5. #20
    Sep 2015
    ∀ʇOsƎuNᴉW
    remember, I am no expert. I thought I read somewhere that your water can be dumping into the midsection area and it makes it appear that you don't have water coming out the dumps. Maybe your mid and 1 piece was worked on so more water was dumping in the exhaust inside of the midsection other than out the dump tubes.
  6. Likes NICE PAIR liked this post
  7. #21
    Apr 2016
    Victoria bc canada
    There is a lot of water coming from the drilled holes above the cav plate for exhaust in the mid... hmm, btw I appreciate the Input from everyone!
  8. #22
    Dec 2011
    Ludington michigan,on the shore
    Your going to need to pull the power head.Your dumping to much water out the bottom of the plate.Is this a salt water plate? Some of them the dump holes are ate out,it don't take much of a bigger hole to lose a lot of water.Could also have a bad gasket.
  9. Likes NICE PAIR liked this post
  10. #23
    Apr 2016
    Victoria bc canada
    Never ran in salt... you should see this motor... it actually looks like it just came off the assembly line, a extremely reputable guy sold it to me and said it was a reman motor, not a lick of corrosion or even oil/grease for that matter...
  11. #24
    Apr 2016
    Victoria bc canada
    I've been working in the marine industry for over 12 years by the ocean, I've seen my fair share of crusty salty motors and I can honestly say this motor has not been near the salt haha
  12. #25
    Dec 2011
    Are you sure it has two of the proper gaskets under the PH
  13. #26
    Apr 2016
    Victoria bc canada
    Can't cofirm that until I pull the power head..
  14. #27
    TX......somewhere?
    what year?.. first (early) 245/260 adapters had "big" holes in adapter.....
  15. Likes NICE PAIR liked this post
  16. #28
    Apr 2016
    Victoria bc canada
    It's a 97
  17. #29
    TX......somewhere?
    mighta gotten smaller by then......... to many brain cells burnt ta remember for sure..
  18. #30
    Apr 2016
    Victoria bc canada
    Haha fair enough, I'm gonna **** with it a bit more before I start pulling the power head, exhaust plate and heads, seen a few YouTube videos of 260's running on the hose and they're not pumping water through the dumps too..that's why I thought maybe it was just the nature of the beast...
  1. Flowing injectors 2.5
    By liberatorx2 in forum Technical Discussion
    Last Post: 02-21-2014, 10:14 AM
  2. Oil to the top bearing.....its in the hose, but not flowing much?
    By WATERWINGS in forum Technical Discussion
    Last Post: 08-11-2010, 09:09 AM
  3. Labbing a prop and flowing the injectors..
    By JW in forum Technical Discussion
    Last Post: 10-19-2002, 05:44 PM
