Results 16 to 23 of 23
02-16-2017, 07:29 PM #165000 RPM
- Jan 2013
- N/A
- 164
- 7
- 7
- 13
- 48
This thread reads like obfuscated bullsh!t, just saying...
02-16-2017, 07:44 PM #17Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
That's from an expert!
02-16-2017, 08:03 PM #18
The gimmick is transverse flow, your going WAY too S L O W. ..................
Yeah don't put a plate on your lower unit It will slow you downWe have invented the world; WE see
FMP liked this post
02-16-2017, 08:15 PM #19Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
02-16-2017, 09:17 PM #20Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Lots of info and plenty of links http://www.google.com/patents/US5458078
02-20-2017, 01:44 PM #21
I've worked on many race tunnel boats since the late 1970's and have tried many different ideas for sponson shapes to help turning and acceleration/speed.
The transverse flow (water spray) doesn't seem to happen, like your sketch, on the race boats. This water spray comes up almost vertical and hits the lift strake
on the vertical tunnel side.
I'm not sure why you've added the pads to your sponsons, but we always like to test one design change at a time. Test the boat as designed/built and then decide
if the boat needs changes to run correctly. There are a lots of things going on in tunnel boat design. Even prop design can make a huge difference.
Mark N
Here is a SST-60 boat I designed and built. I used Jim Russell's TBDP to design the wing section of the tunnel and used a new technique
for the other parts of the boat.
https://youtu.be/_hJf8Sigpt0
"I'ma motorboatin' sonuvabitch!"
Jimboat thanked for this postJimboat, WillySteve liked this post
03-24-2017, 08:45 AM #22
Agree with Mark's comments. There is a "Whisker Spray" that can generate some drag in some circumstances, and effectively designed spray rails can reduce this.
WillySteve, home made tunnel liked this post
03-24-2017, 09:48 AM #23
My little 10' Cougar Cub tunnel needs a fin to come out good! I installed one from Bob's and it now leaves really nice. Before at the high engine height it blew out really bad!
Actually on N2o it initially clears the water!
This little boat wasn't made to run 60 but it handles extremely well at that speed. IMO it needs to be a few more feet longer though!
The tunnel is 8" deep in the front and 5" in the back with no pads!
WillySteve Hendricks
20XDC Bullet/Modified Merc 260
295TF Charger/ProMax 225x-Sold!
'83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
'85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
Freedom 240 DLX Fisher Toon/Merc 115
10' Cougar Cub/Merc 25HP On The Bottle!
18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
Jimboat, home made tunnel liked this post
fuel flow question
By Garmin in forum Technical DiscussionReplies: 6Last Post: 06-02-2011, 10:34 AM -
OMC Tech: X-FLOW Jetting question
By wrechin2 in forum Technical DiscussionReplies: 8Last Post: 04-28-2009, 08:45 AM -
air flow question
By DAVEO in forum Technical DiscussionReplies: 4Last Post: 01-23-2006, 10:48 PM -
OMC x-flow question
By emac in forum Technical DiscussionReplies: 5Last Post: 08-25-2003, 06:05 PM
