Results 1 to 6 of 6
    Apr 2016
    Victoria bc canada
    STV EURO hydraulic trim pump bulkhead fittings
    Has anyone on here ran hydraulic trim pump lines thru the deck ( bulkhead fittings ) for a 245/260 hp merc single ram trim pump? If so what fittings are needed? Running my hydraulic lines the same way ( bulkhead fittings, already have them ) to clean everything up in the back. Thanks.
    You waiting on which bulkhead fittings to use, before you buy the hoses...or do you already have hoses that you want to use?
    Apr 2016
    Victoria bc canada
    I've got the Trim pump and hoses that go from the pump and thread into the flared fittings at the motor side but insteam of just drilling out holes and running them through with bezels I want to thread them into a water tight bulkhead fitting from the inside of the boat then get other hoses made up to go from the outside of the boat to the motor side if that makes sense.
    Apr 2016
    Victoria bc canada
    I just can't find the bulkhead fittings for the merc single ram trim pump
    Moline,Ill
    "Hoser" is your man!
    Apr 2016
    Victoria bc canada
    I'll shoot him a msg! Thanks!
  1. STV EURO trim pump bulkheads fittings
    By Brookbbb in forum Props, Setup, and Rigging
    Last Post: 02-15-2017, 04:36 PM
  2. Hydraulic bulkhead fittings
    By QuarterHorse in forum Props, Setup, and Rigging
    Last Post: 08-30-2013, 07:23 PM
  3. Bob's trim pump hydraulic fittings
    By Brian Harden in forum Technical Discussion
    Last Post: 10-31-2012, 12:06 PM
  4. Trim pump hoses, what fittings???
    By Liquid Force in forum Technical Discussion
    Last Post: 11-29-2006, 12:54 PM
Mazco
