Results 46 to 60 of 202
Thread: Air Flow / CFM's
02-07-2017, 11:10 PM #46
Not really how a flow bench works .. but I guess you could put a balloon over the port and hook the crank to a spintron and see if the modifications you made blew the balloon up bigger or smaller ...
You mention RPM . A two strokes porting has generally been judged by the time angle area method as apposed to CFM ratings .
Two Yamaha engineers are credited with documenting the ability to measure the mean area of a port and Gordon Jennings took it one step further and came up with the time angle chart , knowing as RPM increased , the allotted time for a port to function decreased .
Where a port's time area falls on the chart will pretty much dictate the power characteristics and if the system is balanced ...
pointer liked this post
02-07-2017, 11:25 PM #47Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
If you are an sae member you can find lots of research and tests on this stuff. Mostly Japanese.
Gordon Blair did lots as well
02-08-2017, 08:26 AM #48
OK , time to move onto cons :
I'll start ..
How bout , Flywheel ................ ............. ............
Agreed , that was a skeery thought . But mine will have stainless guard's next time . Just something about a 3.0L wheel sayin "Made in Korea" that made me think of mentioning it ...
OK , air flow . So it goes in the front half , # 1, 3, 5 take the short way around the outside to the rod slot . # 2, 4, 6 have a somewhat longer way around if the air is influenced by the rotation of the crankshaft.
More importantly , why do the reed blocks burn the rubber and chip the reed's on Merc's and not so much on OMC's .... ? (professor Carson , no cheating LOL )
02-08-2017, 06:41 PM #49Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
korean rubber?
02-08-2017, 06:55 PM #50
LOL .... well power , ya never know ...
I think there's gotta be a pretty good reason why it happens ..
02-08-2017, 09:49 PM #51
Dang Koreans
02-08-2017, 10:12 PM #52Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
02-08-2017, 10:13 PM #53Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Re flywheel some wire mesh in layers of kevlar in the cowl should do it.
Maybe just kevlar?
02-08-2017, 10:56 PM #54
So if the air is meant to go from the crankcase up thru the rod slot , why is the crank side made with sharp corners and the cylinder side floor have the radius ... ?
Wouldn't you want it to be easy to go thru and hard to come back ...
02-08-2017, 11:03 PM #55
Air is being drawn in on one side and the other is compressing it? Less resistance for piston coming down?
02-08-2017, 11:10 PM #56Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
You dont want the air to go back into the crankcase via rod slot
The rod is going back in so it is increases volune a bit to help that i guess not to mention ram effect from upstream in the airflowLast edited by powerabout; 02-08-2017 at 11:40 PM.
02-08-2017, 11:18 PM #575000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
02-08-2017, 11:41 PM #58Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
02-09-2017, 12:03 AM #59
# 1 ) Why do the tips of the Mercury reeds chip and burn ?
# 2 ) If air is sposta only go up thru the rod slot , why do they flow better going the other way ?
02-09-2017, 12:09 AM #60Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
1 too much cc compression due to all the air going back into the crankcase ( do port n stb chip the same?)
2 sell lots of reeds
Hmmmm to flow or not to flow
By tunnelingus in forum Technical DiscussionReplies: 9Last Post: 09-21-2007, 05:05 AM -
200 X-flow???
By stealthperf in forum Technical DiscussionReplies: 29Last Post: 08-28-2007, 04:44 AM -
Need x-flow help
By lokinutz in forum Technical DiscussionReplies: 17Last Post: 06-20-2005, 05:18 PM
