Page 3 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 31 to 45 of 202
  1. #31
    Sep 2015
    Twin Cities, Minnesota
    Quote Originally Posted by W2F a V-King View Post
    You mean like the old Ford V V carburetors, 2 barrel Variable Venturi? Those were a real PIA to work on, but when it was right, it out performed some smaller 4 barrel carbs.
    That was just before Ford switched to EFI motors.
    You forgot to mention it had a square bore with a sliding "plate"
  2. #32
    8 Post(s)
    Quote Originally Posted by Krazymaan View Post
    Here is an opened up exhaust chest with proper ramps
    Attachment 366443
    I cant believe nobody has made a spacer block and made a larger plenum and or cut it away at the bottom and use custom adapter as well
    All the modified exhausts on omc triples are about a straight shot out of the port before you turn it.
    49ci and 120+ on carbs....but no rod slots
  3. #33
    8 Post(s)
    Nobody mentioned air speed through a 2 stroke, thats a very critical part not just cfm
  4. Likes RBT liked this post
  5. #34
    May 2014
    Livingston, Louisiana
    Yes, great point. Velocity is just or more important than volume. One without the other equals turd. You get them both and you got a beast.
  6. #35
    Feb 2005
    Muskoka Canada
    see attached. It is a merc part.
    Velocity is everything, why the SVS works better than the AMS. The exhaust is a 2.5 is narrow, the exhaust has to change direction, or be bounced off the floor of the block etc
    2023 TUFF 25
  7. Thanks David - WI thanked for this post
    Likes powerabout, Freddie Webb, Slimm liked this post
  8. #36
    Aug 2015
    NE Tennessee
    No. It didn't.
    It had round throttle blades and bores like most any carburetor. Two of them.
    The square slides you see when you look at a picture are the air control slides. You could stomp the throttle WOT and those slides moved back slower, controlled by a large vacuum diaphragm, regulating venturi velocity to keep it at its maximum.
    Worked really well, but was a pain to rebuild and get it set up correctly.
    I am unsure how the SVS slides work, haven't researched them.
    In this diagram below you can see the gasket and round openings for the throttle blades.
Name:	Ford VV Carb.gif
    But anytime I see those square openings on the SVS, I think back to Ford Variable Venturi carb.
  9. #37
    Nov 2013
    Oak Hill Fl.
    I remember working on those carbs. The ford LSG commercial 4 cyl eng that we used in the JLG lifts had them on it when thy first cam out in 1980. It was there attempt at making a pinto eng a power source unit. Belt driven governor and all.
    What a piece to say the least........LOL
    Once thy dropped that carb and went with a Zenith all was good.
  10. #38
    Aug 2015
    NE Tennessee
    Yes, they were really sensitive. I rebuilt many of them at the Ford dealership I worked at in the mid 80's. Delicate and required special tools to calibrate them. All the techs that did driveabilty hated to see those come in.
    But when they were right, they were really good. But not for to long!! So glad the throttle body injection replaced them in later years.
  11. #39
    Sep 2015
    No. It didn't.
    I was just a teen back then. So i guess its ok to acknowledge that i was wrong. Just going by what I saw. Just remember square holes that gradually opened up.
    But I really do miss my mustang II 74-78' that had a (correct me if i am wrong) 2 liter 4 banger german engine because the intake and exhaust were on opposite sides and you could scream that motor till there was no more scream. Some variation of a cosworth engine. It was just wicked. Huge head and back in the early 80's it kept up to the big boys on the freeway until it redlined at I believe 101mph. Had huge like 12" wide tires on 13" rims. Some of the crazy stuff you come across back then.
  12. #40
    8 Post(s)
    What you need is a flow bench that starts and stops as per piston going up and down
  13. #41
    V-6 Two stroke Outboard powerhead :
    Pro's :
    Simple
    Few moving parts
    Easy to work on
    Lightweight
    Large displacement for such a compact design
    Can anyone else come up with anymore Pro's ... ?
  14. #42
    8 Post(s)
    Pro's :
    Simple
    Few moving parts
    Easy to work on
    Lightweight
    its the only sensible use for a v6 other than a Detroit 6-92
    and we are just waiting for aftermarket DFI system
  15. #43
    Sep 2015
    Pros.
    Loud
    Fast
    Fun
    Sounds cool
    Fast reving
    Looks
  16. #44
    Pros.
    Loud
    Fast
    Fun
    Sounds cool
    Fast reving
    Looks
    LOL ... Krazy , I'm gonna agree with ya on everything except fast ... but lets save that for the "cons" ...
    Power states :
    Well power ... every Superflow I've been around has had a "power switch" right there on the front panel ... stop and started every time ...
  17. #45
    8 Post(s)
    Power states :
    when I say start and stop I mean reversing the airflow at rpm
  1. Hmmmm to flow or not to flow
    By tunnelingus in forum Technical Discussion
    Last Post: 09-21-2007, 05:05 AM
  2. 200 X-flow???
    By stealthperf in forum Technical Discussion
    Last Post: 08-28-2007, 04:44 AM
  3. Need x-flow help
    By lokinutz in forum Technical Discussion
    Last Post: 06-20-2005, 05:18 PM
