Results 16 to 30 of 202
Thread: Air Flow / CFM's
02-01-2017, 10:12 PM #16
FMP liked this post
02-03-2017, 09:36 AM #17
Good read up there ^^^ Just not agreeing with the 350 chevy and a carb bigger than a 600 cfm being to big.......maybe on a daily driven hot rod street car, maybe not even then.
Depends on cam, heads, intake design, valve-train, designated rpm, VE of said motor, rotating assembly capable of desired RPM, etc.... If I remeber correctly a 358 CI NASCAR motor is LIMITED to 830 CFM...
Me personally...I choose the cam I need to get me what I want, then build the motor around that.
But back on topic vv...
If you could come up with a waterproof, non oil fouling O2 sensor, preferably a wide band for better tuning accuracy. You could indeed build an ECU to do just that. MegaSquirt makes several combinations of ECU, PCMs to do this. Just no two stroke O2 sensors for long term closed loop operation like your suggesting. It would be great, indeed!
There is a member here that has a great deal of experience with this and has made and runs a MegaSquirt system on his 2.5 Merc.
Has a Youtube channel.... https://www.youtube.com/user/panronnie/videos
Just no feed back control, or closed loop control due to no O2 feedback. He has incorperated EGT into his though. Maybe he will chime in here somewhere....
As far as CFM's and outboard motors....good thought there, actually never have seen any numbers myself.
First question that comes to mind is does a two stroke need twice the air flow as a four stroke?
Two strokes cram the 4 strokes operations into 2 strokes. With 2 stroked leaking some flow to scavenging and bleed over losses. One would think so anyway, minus the slight loss mentioned.
Great thread !! Subscribed....James H. W2F a V-King... Want 2 Fly a V-King
02-03-2017, 11:03 AM #18
YES a 2stroke pumps twice as much a some rpm as 4 stroke my son runs a 406 sbc and 1050 carb its a animal 68 camaro 6 sec 1/8 mi! flow formula i found to be close for 2 cyc is horsepower x 2.5 = cfm needed.
W2F a V-King liked this post
02-03-2017, 06:12 PM #19
RAISING compression on a hipo motor just levels the playing field. the longer duration in port or valve timing decreases time ports are CLOSED. DYnamic cylinder pressure would decrease , power would suffer, its a trade -off same as big cam and low domprression in 4 cycle=DOG
02-04-2017, 10:06 AM #20If I don't ask any questions, I'll never learn anything.
02-04-2017, 01:34 PM #21Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Nothing wrong with an 800 Quadrajet that has been properly built and tuned.
02-04-2017, 01:41 PM #22
OK so let me ask this.
What is the choke point on a merc 2.5 V6 or put a different way what limits the flow?
Carb's?
Reed blocks?
Case?
Timing?
Sleeve ports?
Ex chest?
Adapter?
02-04-2017, 01:59 PM #23
Exhaust chest
2023 TUFF 25
bigbluechevy454, Freddie Webb liked this post
02-04-2017, 02:44 PM #24
02-04-2017, 03:40 PM #257000 RPM
- Central Florida
- 2,644
- 37
- 32
- 219
Excellent example of misunderstanding about CFM. Since even the smaller Quadrajet flowed 750 cfm the Holley 780 offered little or no performance advantage but a lot of opportunities to screw things up. Or perhaps easier tuning if other significant engine modification were also done along with the Holley.
Maybe the few folks doing outboard hard parts were smart enough to just not bother quoting CFMs.
02-05-2017, 10:05 AM #26
02-05-2017, 11:14 AM #27
I HAD a s/p drag race nova that wheel-stand running a q-jet (foot brake). i think a svs set up functions a like takes in only what engine needs.
02-05-2017, 07:01 PM #28
Gonna be a screamer, high rpm motor. Fo Sho.
What you loose down low, you will get up top.
How about the cylinder port work?James H. W2F a V-King... Want 2 Fly a V-King
02-05-2017, 07:08 PM #29James H. W2F a V-King... Want 2 Fly a V-King
02-06-2017, 01:00 AM #30
Hmmmm to flow or not to flow
By tunnelingus in forum Technical DiscussionReplies: 9Last Post: 09-21-2007, 05:05 AM -
200 X-flow???
By stealthperf in forum Technical DiscussionReplies: 29Last Post: 08-28-2007, 04:44 AM -
Need x-flow help
By lokinutz in forum Technical DiscussionReplies: 17Last Post: 06-20-2005, 05:18 PM
