Results 1 to 9 of 9
    May 2011
    alabama
    2015 250 xs reman block question
    Are the rubber plugs in-between the cylinders on the 3 liter suppose to be in the block are maybe they left them out by mistake ? I have #2 melted down with only 9 hrs on it ? 250 xs 2015 reman powerhead
    It's not that melted looking gob of goop?
    May 2011
    alabama
    No I had to look again that's not them just wandering if it caused it to get hot I have never seen #2 go bad looks like without the plugs it might have trouble cooling the top cylinder..
    Oh dear.
    if the rubber is missing then its what has happened,
    This is why there should be cast in walls instead of daft rubbers that can shift (or be forgotten to be put in).
    going to be hard to prove the rubbers were not in there, is the other side the same ?
    What happened to the previous power head?
    I was thinking the very same,
    as soon as you see re=manufactured makes you start to wonder how many have gone bad and why
    May 2011
    alabama
    Well I left the starboard head still in tact so it will be my only proof,, the previous power head inj got it #6 funny thing I never got a hot horn or I didn't hear it but it is working I just hope they help me out .
    Did anyone check the injectors after the first meltdown?. If the head for that side had to be replaced somehow the injectors were moved around and 2 got what 6 had previously. I'd send the air and fuels out for evaluation. Be sure to mark what cyls they all came from.
    May 2011
    alabama
    Yes injectors and rails were cleaned.a nd checked after #2 melted freeze frame shows over heated.
  1. Is this a 300x Reman or New from Merc block? It's black
    By syclone01 in forum General Boating Discussion
    Last Post: 06-28-2009, 07:55 PM
  2. 260 EFI Parts on Merc Reman Block
    By scott reierson in forum Technical Discussion
    Last Post: 10-17-2008, 10:20 PM
  3. Question of Jaco's Reman-Powerheads?
    By mbrown67 in forum General Boating Discussion
    Last Post: 08-12-2002, 11:49 AM
  4. Question on Jaco's Reman-Powerheads?
    By mbrown67 in forum Technical Discussion
    Last Post: 08-12-2002, 11:39 AM
