Results 1 to 15 of 20
    Johnson evinrude Omc SPRING CLEANING looper crossflow 90-250hp
    Girlfriends pregnant, wife's pissed
    Looking to get rid of the carb and ficht stuff I have laying around. I Need to make some room, I have everything from cowling to propshaft 88-2001. Id like to sell it to a member cheap before it goes on the chopping block on eBaY. Instead of paying eBay I will donate to S&f. I'm working on a list but in the mean time let me know what your looking for.
    Kevin
    Quartershot T-3R 15" E-Tec 1.62 sportmaster
    Sep 2015
    ∀ʇOsƎuNᴉW
    Dont you hate it when your girlfriend tells you that you can't see your wife anymore.
  3. Likes baja200merk liked this post
    Jun 2009
    central minnesota
    building stock(two O.S. pistons)115 eagle for my '69 Ventura 1.need head(1),stator,regulator, power pack,trim unit( I think),maybe others, i will look tomorrow.thanx-th
    Sep 2002
    Merritt Island,Fl. Sunshine Syndicate Country!!!!
    I'll trade you a running 20" ficht for my 25'' etec.
    Bobby Pazos- Member Of The
    BULL-FROG EYES DRAG RACE TEAM
    Fellow-G-Man,
    Sunshine Syndicate
    2006 23' Action Marine 300 HP V8
    2001 19' Action Marine White Power
    1998 23' Concept CC (sold)
    1999 17' Action Marine (sold)
    1996 STV River Rocket (sold)
    Mississauga Ontario
    Do you have a set of the early large connecting rods for a v6 looper?
    1991 Hydrostream AE-21 1997 Evinrude Vindicator 225
    I have a complete 60* but not much ignition parts for those.
    Yes i have a couple sets of long rod old and new.
    Jun 2001
    South East Georgia
    How about a brand new never used 2.7 block with finger port bosses ?
    TMc
    1984 Allison XR2002
    1987 2.7 Fuel Injected Evinrude
    16" Taylor mid
    Brucato ACU.
  9. #8
    I just sold a ported 2.7 with fingerports poked to 3.0. Fresh water never had paint on it since New only the alodine gold coating. Fresh water too.
    I do have sone open deck blocks with bosses.
  10. #9
    Aug 2004
    TARPON SPRINGS FLORIDA
    Do ya have a carter electric fuel pump? I have a 2002 225 I am working on
  11. #10
    I’m sure but I’d buy a new one.
  12. Likes Instigator liked this post
    Jul 2009
    spokane
    I m looking for a 2.7 flywheel ???
  14. #12
    Aug 2004
    Ok thanks I'm trying to solve a problem before I spend 929$ on that pump
  15. #13
    Scrapped 17k lbs of old stuff don’t have much left now this thread is almost a year old.
    Jimmy the pump pump is under $300. What’s the problem? What’s fuel pressure? Usually they work or they don’t.
  16. #14
    Aug 2004
    I have replaced the lift pump. The person I just purchased it from said it needed a new lift pump. Compression is 129-130 psi. I don't know the fuel pressure? The motor will run perfect on the hose for about 30 minutes. Then it will start to stumble then die. The squeeze ball is hard
  17. #15
    Aug 2004
    It takes about 10 minutes before it will start up and start the whole process over again
Simon Motorsports
