Results 1 to 1 of 1
01-23-2017, 12:57 AM #1
Another way of getting around a corned by precutting segments before hand !
Attachment 365304
This is another way of getting foam around a corned ! Set a bench saw to the right angle and the fence at the right distance and can precut enough for all the corners!. In this case the core is 40mm thick ,but thinner core can be done the same way!, strength is this case was not an issue , sound insulation was more important as this is a part of the companion way to the engine room and part of the upper deck support panelsMessing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
Another way of getting around a corned by precutttung the segments before hand !
By tunnels in forum Fiberglass and Composites DiscussionReplies: 0Last Post: 01-23-2017, 12:56 AM -
Wanted nice Merc Left hand Flywheel and 2 or more left hand starters...
By Mike Nass in forum Parts WantedReplies: 6Last Post: 06-24-2016, 02:31 PM -
left hand gear case and right hand the same?
By Quinten in forum Technical DiscussionReplies: 4Last Post: 06-27-2015, 09:57 AM -
left hand gearcase running in right hand rotation?
By david laser86 in forum Technical DiscussionReplies: 19Last Post: 08-26-2004, 07:09 AM
