Results 1 to 15 of 25
Thread: 2000 merc 150efi timing
01-20-2017, 09:20 PM #1Member
- Jan 2017
- Florida
- 37
What should the timing be at wot? Or if it's set as manual says at 23 what will it be at wot? 25? I don't have the idle stabilizer hooked up.And I mix my oil.
01-20-2017, 11:03 PM #2
23 is wot, 25 is max you want to go on pump gas. Idle timing set to preference of idle speed in gear. If it has cdm ignition be careful because will not give all timing until above 5000 rpm. If switchbox ignition set it to 23 at wot. Hope this helps.
01-21-2017, 04:29 AM #3Member
- Jan 2017
- Florida
- 37
How do I tell the difference ?
01-21-2017, 07:32 AM #4
Switchbox ignition will have the two boxes stacked on top of each other on stbd side and cdm will have black plastic module on top. Thought 2000 was cdm. Make sure you don't have any black plastic plastic modules hooked to ignition before setting timing.
01-21-2017, 07:36 AM #5Member
- Jan 2017
- Florida
- 37
Ok i believe it is the CDM because i have the black plastic module. How do you time it then?
01-21-2017, 08:03 AM #6
Not 100% sure I think it takes away 5 degrees timing up to 5000 rpm. I know some do it on trailer to where prop can cavitate and actually bring it above 5000 rpm to make sure all is working correctly. But other than that not sure what manual says to set the timing at static, I would guess 5 degrees less than desired? I'm not dead set on the 5 degree thing, hopefully someone will chime in to clarify it for both of us. I do know if you set it static to 23 you'll fry it lol
01-21-2017, 08:12 AM #7Member
- Jan 2017
- Florida
- 37
I took this picture from the internet..mine looks just like this on the side..
http://i62.photobucket.com/albums/h109/whays/004.jpg
01-21-2017, 08:13 AM #8Member
- Jan 2017
- Florida
- 37
except mine has a black box on top above both heads.
01-21-2017, 08:15 AM #9Member
- Jan 2017
- Florida
- 37
01-21-2017, 08:35 AM #10
Its a switchbox. Disconnect the two black boxes and set timing with boxes unhooked.
01-21-2017, 08:40 AM #11Member
- Jan 2017
- Florida
- 37
I have the port side box disconnected. What is the box on the port head there? And i believe I have a box on top of the starboard head also but not 100%. So disconnect the idle stabilizer and what else?
01-21-2017, 08:57 AM #12
Module on top is detonation control module, it can remove a couple degrees timing when senses detonation. (The big plastic one) I always like to unhook it when setting timing to make sure I'm reading the max timing could possibly be, the module can only remove timing. Module on side is idle stabilizer, but looks like you got that. These should be only two hooked to ignition.
01-21-2017, 09:06 AM #13Member
- Jan 2017
- Florida
- 37
I have the idle stabilizer removed completely. Can the other also be removed?
01-21-2017, 09:10 AM #14
It can also be removed
01-21-2017, 09:14 AM #15Member
- Jan 2017
- Florida
- 37
so remove it. remove all plugs except #1, disconnect the throttle linkage, hook timing light up, hold it WOT while turning the engine over and set it to 23??
I tested the TPS last night and got it to .256 i think it was(between .240-.260). Since i mix my oil how can this affect it running lean or rich?
needing help with 96 merc 150efi
By tinter in forum Technical DiscussionReplies: 10Last Post: 07-07-2013, 06:55 PM -
Mercury Tech: 3.0 250 merc wont rev up past 2000 r.p.m timing goes haywire
By SCOOBARON in forum Technical DiscussionReplies: 4Last Post: 03-31-2012, 01:29 AM -
Mercury Tech: 2.5 merc 150EFI
By venus79 in forum Technical DiscussionReplies: 4Last Post: 06-30-2009, 11:08 AM -
Timing Problem 2000 Merc EFI 175 HP
By coork in forum Technical DiscussionReplies: 0Last Post: 03-28-2006, 07:19 PM -
Merc 150EFI - more power?
By GFO in forum Technical DiscussionReplies: 1Last Post: 03-23-2004, 04:00 PM
