Results 1 to 11 of 11
Thread: Plug for MERC 849849 CPU
01-20-2017, 07:34 PM #1
I need the connector that plugs into the ECU side of the box (also would like to know the "technical" name of the connector). I don't care if it is the adaptor for a 4-button on the other side or a cable that has a USB on the other end. It could also not have nothing on the other end of the cable! I just need the ECU side to plug into the ECU with a minor amount of wire with it and have NO clue where to start to find this thing LOL!!!
Thanx
Schramer
^^^^^^ This is what I need^^^^^^
PLEASE HELP!I have a boat or two.... that I never get to drive
01-20-2017, 11:08 PM #2
Somewhere I have all the parts to make both the male and female parts, they are all made by amp.
2023 TUFF 25
01-21-2017, 10:11 AM #35000 RPM
- Feb 2005
- thibodaux la
- 415
Think I have one I will check
01-21-2017, 02:29 PM #45000 RPM
- Feb 2005
- thibodaux la
- 415
I can't find it must have threw it away
Schramer thanked for this post
01-21-2017, 03:03 PM #5
01-21-2017, 08:37 PM #6
I think I have the crimper for those pins, if you need to borrow it... just mail it back when you're done with it.
01-21-2017, 08:41 PM #7
01-21-2017, 08:49 PM #8
I think this is the other half: https://www.bmotorsports.com/shop/pr...oducts_id/1098
01-21-2017, 08:53 PM #9
David that looks correct. Think that is where I bought them. Most of the parts for the Ecu are readily available except the board and case
2023 TUFF 25
01-21-2017, 09:07 PM #10
The 1st one is the end that I need.....the second one looks like the ECU side which I have. I need an USB end connected to the MALE Merc end or a way to wire the 2 together which is NOT just connecting wires LOL!
01-21-2017, 09:34 PM #11
USB? Your going to need a rs232 interface too
2023 TUFF 25
849849 merc ecu
By motorhead2 in forum Parts WantedReplies: 1Last Post: 09-27-2019, 02:45 PM
