Results 1 to 5 of 5
01-18-2017, 04:11 PM #1Junior Member
- Jan 2017
- St Pete down town
- 10
Evinrude xp150 leaking oil on lower unit on the sides
Hi I just got a new boat to me. The engine runs great but is leaking a bit of oil on the sides of the lower unit. It is not leaking under the cowling at all. 1988 eliminator sprint
01-18-2017, 04:33 PM #25000 RPM
- Apr 2005
- Canada, East!
- 518
- 10
- 11
- 304
- 50
- 2 Thread(s)
Looks like it's leaking out of the lower cowling / pans ...
Take the lower cowlings off and take a look. Likely power head gasket.
pointer
Buehler45 thanked for this post
01-18-2017, 05:07 PM #3Junior Member
- Jan 2017
- St Pete down town
- 10
Thanks for the quick response. I will be fixing it shortly then. is it bad for the engine to run with the lower power head gasket leaking like that?
01-20-2017, 07:19 AM #45000 RPM
- Apr 2005
- Canada, East!
- 518
- 10
- 11
- 304
- 50
- 2 Thread(s)
Once you pull the pans you'll see where the origin is. A power head leak on the exhaust side if left long enough could erode the mating surfaces.
pointer
01-20-2017, 01:28 PM #56000 RPM
- Oct 2003
- LAGRANGE, IL
- 1,277
- 11
- 14
It's probably the powerhead base gasket. Once it goes, you will get the excess exhaust residue leaking down the top of the midsection.
Likely need to pull the powerhead and repl the gasket. It's not a fatal problem that will destroy the engine. But the smoke that leaks out of that gasket area will fill the inside of the cowling when the engine is running. Much of that smoke will get re-ingested in the carbs and sucked back into the engine. That's the bigger problem.
Leaking lower unit
By headgames in forum Technical DiscussionReplies: 8Last Post: 10-07-2011, 09:05 PM -
Lower Unit Leaking Oil
By larsonblue in forum Technical DiscussionReplies: 11Last Post: 04-19-2010, 01:11 PM -
Leaking Lower Unit
By bigantmitch in forum Technical DiscussionReplies: 1Last Post: 11-07-2009, 07:58 AM -
OMC Tech: Water leaking out of lower unit
By primerate2 in forum Technical DiscussionReplies: 7Last Post: 07-03-2009, 06:26 PM -
Mercury Tech: leaking lower unit
By red bullet in forum Technical DiscussionReplies: 3Last Post: 12-28-2008, 04:09 PM
