Results 1 to 4 of 4
Thread: Mercury Optimax 90 goes out
01-17-2017, 03:18 PM #1Member
- Nov 2015
- Chicago
- 92
- 39
- 29
Hi.
I have a strange problem.
Sweeping after pressing the i button trim always immediately extinguished.
There are no errors.
It's hard to run it.
He can also go off for no reason.
Battery voltage is good. Charging too good. No voltage drops after pressing the trim. Bolt is sparge plug. The entire fuel system checked and efficient. As the engine turns off at this point injectors are switched off - pump is running and gives pressure.
Has anyone had a chance?
01-17-2017, 07:55 PM #2
Have you load tested the battery? Had one a while back with good voltage and cranked motor fine but it ran like crap. Ran fine on the second battery so I load tested battery 1 and it failed miserably.....shows how sensitive these motors are to bad batteries.
01-18-2017, 02:38 AM #3Member
- Nov 2015
- Chicago
- 92
- 39
- 29
Attempts were 2 batteries.
My impression of the damaged wiring harness remote control
or computer PCM
01-19-2017, 12:38 AM #4
The motor I just mentioned ran fine on only the good battery. With the switch on both batteries it would not run either. Sounds like you need to find a short to ground in your situation.
250 Mercury Optimax NOT XS
By noli in forum Ebay Listings and Other Internet ListingsReplies: 0Last Post: 01-17-2016, 08:52 AM -
Mercury Optimax DFI oIL
By harrells in forum Misc. Parts and AccessoriesReplies: 0Last Post: 07-21-2013, 08:38 AM -
Mercury 300 Optimax XS
By hfc1951 in forum Technical DiscussionReplies: 1Last Post: 04-24-2011, 06:40 AM -
200 HP mercury ob optimax
By tgboatdoctor in forum Technical DiscussionReplies: 0Last Post: 07-08-2009, 06:50 PM -
Mercury OptiMax 200
By champ204 in forum General Boating DiscussionReplies: 4Last Post: 07-16-2002, 11:29 AM
