Results 61 to 75 of 215
Thread: 1971 Donzi Classic 18 power....
01-23-2017, 09:36 PM #61Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Before you do that I would tack your Merc drill template bracket and post a few pictures and let some of the guys here who have done it take a look. Your in Michigan, another week to think aint gonna hurt a thing.
01-23-2017, 09:38 PM #62Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Can you not make up the last sections of the exhaust to widen the pipes or whatever is needed to give the clearance needed to raise the drive up? Maybe dump out the sides of the hull.
01-23-2017, 09:50 PM #635000 RPM
- Jan 2017
- Waterford Michigan
- 104
- 17
I could exit the exhaust somewhere else. A month ago I thought I'd run with 16" up, but am nervous I'd push myself into a remote pickup and a four blade prop...
01-23-2017, 09:55 PM #645000 RPM
- Jan 2017
- 104
- 17
Template setup for outdrive
Here's the setup....it's at 14-1/4. I have a hole higher up at 16" above hull bottom. Not sure what's up with the picture rot....
01-23-2017, 10:02 PM #65Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
01-23-2017, 10:02 PM #66Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Capt.Insane-o liked this post
01-23-2017, 10:03 PM #675000 RPM
- Jan 2017
- 104
- 17
Thanks! I am on a cell and my computer is being replaced
01-23-2017, 10:11 PM #68
On the transom shield, the Bravo's have a known problem with the water inlet where it passes through the shield (transom housing) if it has been used in salt water. Take the water neck off from the inside of the housing and take a pic and post it here. There is a plastic inset inside the hose where it passes through the housing and the housing will corrode and collapse the hose.
Classic18 thanked for this post
01-23-2017, 10:17 PM #69Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7148
- 3 Post(s)
When you talk to Tyler, ask him about starting out with a 350 mag (you can find them reasonable, change the exhaust, heads, cam and add F/I). I did one for my uncles old baja 190. It picked up 12 mph and acceleration was night and day. There is a guy down here in central Florida that runs his 18 at all of the historic races held at Mt. Dora-its pretty serious when he gets in it for any length of time. I will ask about him when we go on their fun run in two weeks and try to get you his contact info.
01-23-2017, 10:20 PM #705000 RPM
- Jan 2017
- 104
- 17
Here's the water inlet. As I understand it the donor boat run in the Great Lakes
01-23-2017, 10:31 PM #71
Looks like the corrosion has started, I would get the tool to remove the insert and hose, clean up the corrosion and prime and paint it. If you still plan on going with a through hull pick up, just get the block off plate to replace the water neck and seal in the water pick up holes in the side and front of the lower unit to reduce drag.
01-24-2017, 12:11 AM #72
Told ya this was the place Classic, if these guys don't know or haven't done it...its not worth knowing.
01-24-2017, 12:40 AM #73
01-24-2017, 12:47 AM #74
Oh and it's a lot easier to bolt on a shorty lower than if is to pull the engine and transom assy out re glass the hole and start over.
blacktruck liked this post
01-24-2017, 05:27 AM #755000 RPM
- Jan 2017
- 104
- 17
22 Donzi Classic
By Speed Jr. in forum Hulls larger than 20'Replies: 9Last Post: 07-08-2016, 05:01 PM -
Donzi classic 22
By koukrapock in forum General Boating DiscussionReplies: 12Last Post: 10-29-2012, 05:58 PM
