Results 46 to 60 of 81
01-30-2017, 08:19 PM #461) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
bondo4days liked this post
01-30-2017, 08:33 PM #47
WOW 10 mm sound very excessively thick !!!
Most ordinary power boats even 7 meters long only have between 5 to 7 mm thickness !
THE 147 FOOT boat on the bottom of my avatar was basically 15 mm of solid glass in the hull bottom and then had framing inside !the top sides 5mm outside + 45mm thick divinicell core and 5mm inside skin !
As for flex you maybe surprised at just how much the bottom of your boat actually does flex It may not be visible to the naked eye but over all its will move for sure !! Don't be afraid because its moves it means it wont break as easy !
The flex I like to see looks excessive but yes is softer riding and is stronger that any normal person can withstand without getting seriously hurt !
Using these types of flexible boats for Surf life saving in huge surf have saved numerous serious and minor injuries during there average working day !
Even the military have used this concept of flex and carry heavier loads at much higher speeds in boats that are lighter constructed than there counterparts in earlier times !
Amazing as it seems but close to 40% of the glass used in the manufacture of most every boat made is not necessary !! It means a whole rethink of what should be used and how to get the best from less !!Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
01-31-2017, 06:10 AM #48Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
01-31-2017, 07:53 AM #49
I'm no expert as you well know, however I know the hull thickness on the V-Kings is this thick for whatever reason, and have verified it with another man who has the race version of this boat. It looks like it was a chopper gun blown in skin with cloth laid in on top. Not 100% sure, but I don't see any cloth in these areas where the core has been removed.
As stated before I do see at least two layers of some kind of woven cloth laid in different directions in all areas outside the core, on top of what ever the skin is compromised of.
As far as flex goes..IF it flexes it's very very marginal, and the Pad better not flex at all. Flexing would cause a hook to form and then release, and this would alter boat attitude or the stability at speed. NOT desired. It is the reason these boats are unsafe at higher speeds if the hull has not been checked and or recored to replace the all wood rotten core/stringers and transom.
In fact the guy I bought my boat from could not run it over 70. Said it was a handful. #1 (jmo) He has never driven a boat that had a chine walk issue, and the boat had a soft hull, rotten core, etc... it was flexing under speed, making it unstable.... I knew the condition of the boat. Didn't care, I bought the boat to restore. The hull had no cracks or ruptures, just a soft rotten core/floor and transom.
Unless put there by design. Like the Vector and Viper hulls, have a Wedge designed into the pad at the last 24" or so, built right in. Some call it a hook, which it may very well be. Some remove it, some leave it, but either way it was designed into the hull and does not flex.
I do think...BUT do not know, that the Viper Vector hulls are thinner, as the reason the core on those goes chine to chine, at least from the rebuild threads I have seen. And my Vector that someone else restored, thats what I see. I have not and have no need or desire to drill holes in my Vector. It just needs a repaint and re rig.
Just my findings so far with mine anyway.....James H. W2F a V-King... Want 2 Fly a V-King
01-31-2017, 12:09 PM #50
Tunnels... Here is an example of what the original poster isn't looking for. Just a quick and dirty job is all he needs.
No need to get angry at him, or anyone else not wanting Fiberglass lessons 101.
To the Original Poster Bondo4days - - - If all you want is quick and dirty... Mix some sawdust in with resin to make a thick peanut-butter texture. Put it in a plastic bag and squeeze it out like cake-frosting onto bottom of pad, or forget the bag and just slop it on and spread. Slap on a piece of plywood over that for your core... use more peanut-butter resin to fill in the edges... and throw any cheap glass you can find over the top of all of it...
QUick and dirty... and effective. Cheap!!!
...or forget the core, and just put in a few massive stingers / 2x10 timbers in the same manner on edge. Call it a day.Last edited by home made tunnel; 01-31-2017 at 12:12 PM.
02-03-2017, 10:06 PM #51Junior Member
- Aug 2005
- 24
- 7
Ran a Viper back in the late 70s with a 150xs boat ran low 80s on Radar 30" thru hub cleaver took the hook out of the bottom couldn't get the boat to run lower 70s put the hook back in 80+ instantly.
Tom Madden
Land & sea
XstreamVking liked this post
02-03-2017, 10:14 PM #52
Hook !
03-18-2017, 04:16 PM #53Member
- Mar 2017
- Southern Indiana
- 68
[QUOTE=bondo4days;2920825]Attachment 364670
Those seats are bad ass!
06-14-2017, 09:04 PM #54Junior Member
- Jan 2017
- Ofallon MO
- 29
The shop has been super busy so I haven't been working on the boat but the race is 2.5 weeks away so I got back on it tonight. I got most of the rest of the core out and my 3/4" marine plywood cut. I made the stringers an inch taller and kicked them up to the bottom of the splashwell. I also got my materials in. 2 sheets of 1/2" balsa, 5 sheets of 3/8" balsa 4 gallons vinyl ester resin, cabisil, 1708, some 1.5 Oz chopped mat and some chopped fibers
06-15-2017, 08:26 AM #55Junior Member
- Jan 2017
- Ofallon MO
- 29
06-15-2017, 12:38 PM #56
Looking good. But those will be some long days! And nights!
06-15-2017, 12:57 PM #57Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
06-15-2017, 03:11 PM #58Junior Member
- Jan 2017
- Ofallon MO
- 29
06-16-2017, 08:36 AM #59
Looking really good. Like the cradle you made there.
You think 4 gallons of resin is enough?James H. W2F a V-King... Want 2 Fly a V-King
06-16-2017, 08:57 AM #60Junior Member
- Jan 2017
- Ofallon MO
- 29
Nobody seems to think so so probably not but I am a very firm beliver in only using enough resin to wet out what I am doing so we will see how the stringers and pad core goes down and I will order more if I have to. The cradle was tough because the core was and ready out of the boat and it was flimsy as crap so I jigged it up as best I could and what I think the shape is supposed to be. It's even side to side, the pad is flat and I got the wavyness out to the sides...
Yet another Viper rebuild
By AlaskaStreamin in forum Fiberglass and Composites DiscussionReplies: 389Last Post: 06-14-2016, 06:57 AM -
Hydrostream Viper Rebuild
By Richie21 in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 06-01-2015, 02:42 PM -
Another Viper Rebuild- This Makes Number..... ?
By wireless in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 07-09-2010, 12:49 PM -
By AlaskaStreamin in forum General Boating DiscussionReplies: 44Last Post: 10-08-2009, 09:48 PM
