Results 31 to 45 of 81
01-16-2017, 02:08 PM #31Junior Member
- Jan 2017
- Ofallon MO
- 29
It looks like this boat had no core under the floor and that is how the performance boat shop down the street said to do it...?
01-16-2017, 04:30 PM #32
It had core under the floor
01-16-2017, 04:58 PM #33
Yip a core is not necessary and in a boat that size really is a waste of time ! knowing what is actually there is pretty hit and miss as well, I asked this question some time ago and no one could tell me and even asking the actual hull thickness and that was all guesses . But if you worried about the hull flexing don't !! Because it flexes give's it lots more strength ! make sense ??
01-16-2017, 05:15 PM #34Junior Member
- Jan 2017
- Ofallon MO
- 29
01-16-2017, 05:24 PM #35
Between the stringers there is core under that skin of glass too. That all needs to be removed and the wood block the drain plug goes through too. Under the bow if your careful and patient you can cut the foot rest and airbox out carefully with a sawzall and save it to reinstall. Much of the core under there will be mush. As much being that you are planning a rough water adventure with it just follow the core pattern and glass the air box back in or at the very minimum two bulkheads. Because if and when you stuff the thing at any kind of speed into a wave it will crush the bow in and break it free from the deck if not properly reinforced.
01-16-2017, 08:14 PM #36
01-17-2017, 11:04 AM #37Junior Member
- Jan 2017
- Ofallon MO
- 29
01-17-2017, 11:08 AM #386000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
bondo4days liked this post
01-17-2017, 01:26 PM #39
Use a dehumidifier under a sheet of plastic to completely cover the hull tape it down across the deck opening !! Its sucks out all the moisture from everywhere as in totally !! when the tank doesn't collect any more water the BOAT is dry as in completely every where ! from end to end even under the deck !
01-17-2017, 02:02 PM #40Junior Member
- Jan 2017
- Ofallon MO
- 29
01-18-2017, 08:49 PM #41Junior Member
- Jan 2017
- Ofallon MO
- 29
01-18-2017, 10:00 PM #421976 Hydrostream Viper - 2.5 EFI
Resto Thread Here
2010 Go-Pro Stuff
"The true soldier fights not because he hates what is in front of him, but because he loves what is behind him." -G. K. Chesterton
01-18-2017, 10:06 PM #43Junior Member
- Jan 2017
- Ofallon MO
- 29
01-20-2017, 12:56 PM #44Team Member
- Sep 2008
- Dow, IL \ Theodosia Mo.
- 297
- 17
- 87
- 51
I wanted to be at Two Branch for the race damn.
01-30-2017, 09:55 AM #45
Yes, someone did give the hull thickness under the cored area on a V-King......ME . post #65
http://www.screamandfly.com/showthre...material/page5
10mm average hull thickness under the core. I drilled a few sample holes in mine with 1/16" drill bit.
Also the flex thing might be OK in a slower boat that never airs out or runs on a pad.
A sudden flex in a boat hull coming off a pad, or chine walking and flexing the wet part, even a prop blowing out and the bow drops to quick flexing somewhere that gets wet, could make a bad situation worse. jmo
Maybe in a fishing boat pounding waves it might soften the ride some, and allow for the flexing a small amount to keep it from cracking. Not sure about in that scenario.James H. W2F a V-King... Want 2 Fly a V-King
home made tunnel liked this post
Yet another Viper rebuild
By AlaskaStreamin in forum Fiberglass and Composites DiscussionReplies: 389Last Post: 06-14-2016, 06:57 AM -
Hydrostream Viper Rebuild
By Richie21 in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 06-01-2015, 02:42 PM -
Another Viper Rebuild- This Makes Number..... ?
By wireless in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 07-09-2010, 12:49 PM -
By AlaskaStreamin in forum General Boating DiscussionReplies: 44Last Post: 10-08-2009, 09:48 PM
