Results 1 to 4 of 4
    Dec 2016
    dothan alabama
    99 OPTIMAX FUEL COOLER BYPASS? vst pump wrong?
    I posted here earlier with a problem on a 200. well i come across a good deal and swapped motors. The mechanic i bought from said that the extra fuel line was from a cooler in the 99 optimax 225. Well i believed him got motor home started trying to sort how to run it back to the fuel tank being i have duel tanks and ouch it hit me i never seen a return line to a tank on any boat. Well seems i was right yes its a fuel return from the fuel cooler and should go to the fuel pump. I start looking for a fitting or block plug and then the bad hit me. Its got a 135 hp vst pump on it Family number ym9xmo2.52c0 . no ideas where to go i'm on a very limited income from va. got less then 20 days before my son starts his finale year and has already locked in a scholarship to fish college. Will this pump work and can i by pass the cooler or do i need to try and find a different system. It run great on stand and has less then 80 hours on motor new not rebuilt compression is 103/107 across all
    Dec 2008
    San Diego, CA
    It does not return to the tank.
    I had one rot out. I used a piece of hose to replace the water side and a small piece of hose replace the fuel side. 12 inch max per side. No need to go back to the tank.
    Dec 2016
    dothan alabama
    ok i will see about putting a t in on the main fuel line side of pump or maybe someone will clarify where to run it or pump just wont work'
    Dec 2016
    dothan alabama
    I cant find any good info on bypassing the fuel cooler or if the pump will work correctly once its in the water
  1. Wrong fuel pump?
    By Flatlander in forum Technical Discussion
    Last Post: 02-06-2013, 06:58 PM
  2. Fuel in Optimax air pump
    By ucf_motorcycle in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-02-2011, 08:02 PM
