Results 1 to 15 of 16
    Feb 2011
    Haddam, CT.
    Mercury 300x oil injection hose routing
    I'm just curious. On page 4A-35 of the service manual they show the port side of the 2002 and up engine depicting the oil pump hose routing into the crankcase. On the next page they show the starboard side with hoses running into the cylinders. That's not depicted anywhere in the manual for the port side. Are they only on one side and what's the reasoning for it? The 3 lines going into the sides of the cylinders are depicted in this photo. Thank You.
    1988 Sutphen 31 Race Boat(Great Adventure)1987 24 Skater with Simon Motorsports 335x motors/Taylor 15" Mids.
    Waretown, NJ
    The hoses that you see there in that picture are not the oil injection hoses, those are the bleed lines. The oil injection hoses on a 300x go from the oil pump to the fittings on the reed plate. Hope it helps.
    Kevin
    Waretown, NJ
    Here is the oiling system diagram
  4. Likes vnemous liked this post
    Feb 2011
    Haddam, CT.
    Hi Kevin. Thank You. Any idea what the bleed lines do and why only on one bank of cylinders(Starboard side and not on the port)? Just curious.
    Waretown, NJ
    Quote Originally Posted by Sea2jet View Post
    The bleed system is used to re-route unburned fuel that puddles in the engine to try and stop the engine from "loading up". Mostly idling for long periods will cause the fuel to puddle.
    The port side does have some bleed hose fittings but they are not by the cylinders like the starboard side. Here are a couple diagrams of the bleed routing.
    Waretown, NJ
    Starboard Side
    Waretown, NJ
    Port Side
  9. #8
    Feb 2011
    Haddam, CT.
    Thanks for the explanation Kevin. It's very much appreciated. Mike
  10. Likes Kevin_From_NJ liked this post
    Jul 2011
    Albany, NY
    do these lines exist in a 2.5 nic motor?
    I find when I idle my 300x if I trim it up a little it helps with the puddling JMO
    I thought you did that so everybody could hear the exhaust churdlin above the water line ...
  14. #12
    Well you and I know thats the real reason
  15. #13
    Waretown, NJ
    Quote Originally Posted by Snotrekie View Post
    The only one I have seen is the 245 carb motor that has the bleed fittings by the cylinders. I believe that non of the EFI engines have them. I could be wrong tho, I've been wrong before.
  16. #14
    Waretown, NJ
    I thought it was to let everyone else catch up!
  17. Likes vnemous liked this post
  18. #15
    They sound so good .....
    Kev sez :
    Pffftttttttt .... Datz bout rite , he was pickin on a kid in a flats boat wiff a 150 when he had it down here .....
  1. OMC Tech: Water Hose Routing
    By Jim_Pat in forum Technical Discussion
    Last Post: 06-21-2014, 05:11 PM
  2. Mercury Tech: 300X oil pump hose routing ???
    By Go Time in forum Technical Discussion
    Last Post: 07-17-2012, 12:13 PM
  3. OMC Tech: v8 cooling hose routing
    By slowmover in forum Technical Discussion
    Last Post: 03-24-2010, 09:45 AM
  4. Mercury Tech: Routing for hose?
    By Nitro 929 in forum Technical Discussion
    Last Post: 06-16-2009, 03:47 PM
  5. recirc hose routing
    By dwb212 in forum Technical Discussion
    Last Post: 02-20-2006, 02:46 PM
