Results 1 to 12 of 12
    Sep 2016
    Lake George ny
    suggestions on how to re-core a hydrostream
    Have to re-core my hst and dont really know how, looking for any suggestions or tips on different types of wood to use and how to do it.
    thanks
    Glad I didn't have to re-do mine... but there is a lot of HST floor/foam/core info in these:
    http://www.screamandfly.com/showthread.php?45493
    http://www.screamandfly.com/showthread.php?166924
    General HST discussion
    http://www.screamandfly.com/showthread.php?165072
    The psu nuked in my puter I should have my parts tomorrow and I'll answer your pm. I'm not typing it out on this ****ing phone
  4. Likes W2F a V-King liked this post
    Sep 2016
    Lake George ny
    okay,thank you!
    Dec 2011
    Ottawa
    There is no wood core in an hst,other than the center pod.but there is some foam in the bottom tips of the outer sponsons,and then about 4" below the top flats of the sponsons a thin glass layer is layed up,as the bottom of a foam box. The decks are then layed down,holes drilled in spots,to pour more flotation foam into. The lower foam in the tips i believe to be for stiffening the sponsons. The 2nd layer for stiffness and flotation.
    Dec 2011
    Ottawa
    This is one of my canadian edition ae 21,same hull as an hst, the foam runs from the rear corners, all the way forward to about 3' under the dash, you gotta remove the 1/4" decking and the foam is right there, i had 4 big assed contractor bags of the chit,that i could barely carry to the dumpster....lol
    Dec 2011
    Ottawa
    I would post your topic over in fiberglass forum, alot of guys over there can help you also.
  9. #8
    Dec 2011
    Ottawa
    The only balsa core is in the center pad area, from transom forward, where the broom is in the pic.it actually was the best layed up section of the boat,and dry.
  10. #9
    Sep 2015
    Twin Cities, Minnesota
    Quote Originally Posted by Varmint View Post
    I have that same prybar I don't use it much I'm afraid it'll break even though it guaranteed not too. But the adjustable angles DO come in handy at times.
  11. #10
    Dec 2011
    Ottawa
    Honestly that bar is the best tool i have bought for $20 in years, came in real handy under the gunwales and for getting the transom out. My transom wasnt rotten,so harder to delam and tear it out. I like that the bar has a strike face,for whacking it into small spaces under the wood. Dont worry, i pulled some well bonded plywood up with it. No issues at all. I found that they used a ton of stainless screws to layer the transom, that bar paid for itself quickly tearing that chit apart.
  12. #11
    Dec 2011
    Ottawa
    I also used that bar to bust up the foam, then i basically shaved the wet foam, with a dewalt wide wood/drywall blade on my oscillating tool,that made quick work of the foam, w/out any damage to the light glass bottom of the foam box.
  13. #12
    Dec 2011
    Ottawa
    Only good thing about wet foam is no dust,plus the good feeling of knowing the crap is out of your boat ! Lol
  14. Likes W2F a V-King liked this post
  1. hydrostream hst core
    By Gassman109 in forum Technical Discussion
    Last Post: 12-07-2016, 08:21 AM
  2. Hydrostream re-core help
    By FusionFab in forum Fiberglass and Composites Discussion
    Last Post: 04-06-2012, 01:34 AM
  3. Hydrostream Venus Re-core
    By hydrohellion in forum Fiberglass and Composites Discussion
    Last Post: 09-27-2010, 08:14 PM
  4. hydrostream core question
    By rollerzonlyone in forum Fiberglass and Composites Discussion
    Last Post: 12-19-2008, 12:54 PM
  5. new core in the hydrostream
    By cuffer22 in forum Fiberglass and Composites Discussion
    Last Post: 03-07-2008, 06:02 PM
