Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: More power
    Aug 2016
    Lake park, GA
    More power
    I have a 96 mariner mag 2.5l 200 HP. Is there any mods I can do get 225 or 250 HP out of it? Is there a 225 or 250 2.5l powerhead that I can bolt on? Any help and advice will be appreciated. Thanks
    Aug 2016
    Lake park, GA
    Has anyone tried the Dyno-Boost performance chip? Or is it just B's. I would like to just swap powerheads I just don't know what years will fit. But if I had to rebuild the 2.5l block, where can I get good aftermarket/performance parts. Thanks
    Dec 2011
    Ludington michigan,on the shore
    Member here "American ram" I think has a brand new 225PM powerhead for sale.Buy his sell yours,The PM platform is hard to beat.
  4. Likes Dave Strong, Slimm liked this post
    Pekin, IL
    What kind of boat and how do you use it. Above advice is spot on.
    Rock
    Team Junk
    Aug 2016
    Lake park, GA
    Well that's part of what I am asking. What years powerheads in the 225hp through 250 HP range will fit my 2.5l. correct me if I am wrong but 3.0l powerheads will not fit on a 2.5l right? I don't want to get another hole engine, I just replaced everything in my lower unit. Any help will be appreciated
    Aug 2016
    Lake park, GA
    My boat is a 96 nitro savage 896. I fish out of it but I like going fast also lol.
    Dec 2011
    Any 2.5 of any HP rating,as long as its not a sportjet will work on your mid, if you have the proper plate for it.But unless you do ALL of your own work,and are knowledgeable stick with a 225PM! Ya, you can find a little more power here and there, but time,cost,& effort IMO makes anything else a poor choice.
  9. #8
    Aug 2016
    Lake park, GA
    Ok so I can put any 2.5l 225 HP powerhead on my mid, then I will find a powerhead and maybe do an exhaust tuner. I hope the gains will be highly noticeable over my 200. Thanks for the help and information.
  10. #9
    Pekin, IL
    The 225 Promax has to be one of Mercury's brightest spots. Very dependable and a very noticeable difference from a stock 200 and ideal for your application. Good luck and be safe.
    Rock
    Team Junk
  11. #10
    Mar 2010
    houston, tx
    The exhaust adapter ports on your 200 will be a little smaller than what came on a 225 promax, and the tuner is different too. Unless you are trying to race it won't hurt you that bad. I ran a 225 promax on a 200 adapter plate and tuner for quite a while, it would still spin over 7400 easily.
    For or everylast bit of top end change the adapter plate to a 225 promax one and tuner but fishing on your nitro I doubt you'll be able to tell any difference.
    A 225 promax actually makes 247-249hp from those that have dynoed stock ones.
  12. #11
    Aug 2016
    Lake park, GA
    Quote Originally Posted by 90 5.0 View Post
    Ok. Thanks for the help
  13. #12
    Apr 2013
    Lexington, ky
    I think you can grind out the adapter to accommodate the larger exhaust passage of the PM, at least that is what I did. Took a little time and patience as I didn't have an air compressor to use my 'proper' tools so I was stuck with my 18v DeWalt drill and a couple rotary burrs.
    Start Click image for larger version.
ID:	364085 Finish Click image for larger version.
    Slimm
  14. Thanks outasite thanked for this post
    Likes outasite, Dave Strong liked this post
  15. #13
    Dec 2011
    You got her,looks good!
  16. Thanks Slimm thanked for this post
    Likes Slimm liked this post
  17. #14
    Mar 2011
    Virginia
    Yeah, just match the ports in the top plate and your there...the 200 and 225 tuner is actually the same when using the 2 pc adapter.
    Go Time
    26 Regulator twin 250 EFI
  18. #15
    houston tx
    260/drag electronics, good reeds and add some compression to it. That will wake up a stock 200.
  1. OMC Tech: V8 Dual Power Packs to Single Power Pack, what's needed?
    By kimswang in forum Technical Discussion
    Last Post: 11-09-2014, 02:09 PM
  2. Replies: 9
    Last Post: 08-05-2013, 03:20 PM
  3. power head swap for more power
    By wrangler7883 in forum Technical Discussion
    Last Post: 07-20-2007, 10:02 AM
  4. Replies: 31
    Last Post: 04-27-2005, 07:18 AM
