Results 16 to 30 of 33
Thread: Anybody used PP Plasticore ?
12-21-2016, 12:56 PM #16
It seems to me that "toughness" is more important and harder to achieve than outright "strength". The CarbonCore/NidCore info is here: http://www.carbon-core.com/applications-marine.htm#
12-21-2016, 01:04 PM #175000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
I'm sure I will have some but it will be a while before I start using it. I'll try to remember you.
12-21-2016, 01:14 PM #186000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
12-21-2016, 01:19 PM #196000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
So here is a pic of the stringers system, pretty simple, the transom is only square in center of stern, 3/4" plywood wont be very heavy, probably simpler to use ply for stringers, there a couple bulkheads in the grid, but they also act as the ski locker foundation.stringers also only run on top of the coring, which is only in the pad.
12-21-2016, 01:27 PM #206000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
12-21-2016, 01:33 PM #216000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
12-21-2016, 01:34 PM #22
stringers should never have anything attached to them ?? HIGHLY disagree. When you have the floor attached to the top side of stringers, it GREATLY increases the strength and rigidity of them. Essentially turning them from a "T" bar into an "I" beam. Less flex, the better.
The core could really be anything !! it gives little to the stringer strength its the glass you use that's doing all the work. Also Highly disagree. Depends on the core material, and whether it was bonded. For instance, if you use wood as a stringer, epoxy resin and fiberglass is going to bond VERY well, and the wood its self will be the strength, as the bottom edge is glued to the fiberglass hull. The weak point is if you have a thin hull, the stringer may flex side to side (port / starboard). If you put a floor in on top, you're essentially going to be indestructible. . . . take a look at the stringers I put into my bayliner. Just simple 2x6 home depot lumber, cheap, but very strong. Fillet joints on the bottom, and glassed over the top of that.
You want to use the plastic core material though... You may need polyurethane in lieu of epoxy to get the same bond. it will create a strong vertical stringer, but will not be as strong in port-starboard flex as the bow of your boat hits a wave and wants to fold the boat in half.
1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
12-21-2016, 01:50 PM #236000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
Thank all you guys, i really think that i will just use plywood, there is very little stringers in it,maybe 10' in the pad and tied to the lower transom, being full tunnels with the center pod, the deck over the tunnel flat area out to it's edges ties alot of that port/stbd. Flex.there are also knees that tie the topcap back to the deck full length, and topcap is fully glassed to hull
12-21-2016, 01:54 PM #246000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
12-21-2016, 01:56 PM #256000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
Decks were all old chopper gunned 1/4" ply and not much resin,it's an 89 ae 21 same hull as an HST
12-21-2016, 02:13 PM #266000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
12-21-2016, 02:18 PM #276000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
12-21-2016, 02:22 PM #28Screaming And Flying!
- 14,704
- 380
- 1280
- 5599
- 10936
Nice old boat..... If you want to go composite, I would use some coosa board replace the ply. Ply will work good too. Just seal it well.
12-21-2016, 04:59 PM #296000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
12-21-2016, 05:10 PM #306000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
The stringers are actually only 10-12' max, yes they will be bonded directly to the base of the transom and on the center line fwd. They will be bedded on a flush surface ,which is the pad and it is balsa cored. This is the center sponson,the outer sponsons are already tied together about 2/3 of the way up from their bottoms. On top of that was poured foam,and 1/4" deck covering that. The top deck and foam have been removed. Everything will get sanded for some tooth and a fresh sealer of csm and resin. Then i can bed my stringers to that fresh stuff. No foam is going back in the sponsons, nor much deck over outer sponsons. I am using knees to support the topcap, hull in lieu od deck. Much less weight
