Results 1 to 15 of 20
12-17-2016, 09:26 PM #1
95 summerford rr any info on this hull
I recently picked up my first stv from a gentleman in South Carolina it is a 1995 stv river rocket with a 2.5 260 on it. I'm just trying to find any info on the hull and motor. Previous owner said the boat came from Texas and the motor had some work done to it by diamond marine any info on it would be greatly appreciated thanks.
12-17-2016, 11:25 PM #2
Can you still boat in Pennsylvania this time of year?
12-18-2016, 08:41 PM #3
Depends... if you have some arctic carharts or are from Canada you can but normally no. I itching bad to take the new ride out most likely I'll be able to around the end of march. The river by my house hasn't froze yet although some ponds and small lakes were starting to
12-18-2016, 08:45 PM #4
Tried to get a little better pic
12-20-2016, 08:20 AM #5
I would give that cle a little love need to blend that torque tab in with some marine Tex or something I remember seeing it thinking that was a blow out waiting to happen
19 bullet
82 v king
84 v king
93 stv pro comp
07 venom
80 gt20
93 v-21
89 stv procomp
97 xr 2001
89 stv pro comp
82 17 action marine
99 action craft flats boat
88 xr2002
90 Stv pro comp
10 mirage 1/4 master
98 mirage 1/4master
01-01-2017, 11:15 PM #6
Can I just mud it up like a car an just use base an clear on it? How well does marine tex sand?
01-07-2017, 02:50 AM #7
Powerhead is off an about to be on its way to jsre just waiting on the crate to arrive!!!
01-07-2017, 08:47 AM #8
Marine Tex works fantastic, It sands easy too. If you can, buy some long steel files. Flat, round and radiused. They are cheap to buy. With a Steel File there is no mistaking where your low and high spots are so you can add more Marine Tex. The files cut through Marine Text almost like butter. A Steel File is 100 times more accurate than a 1x2 with sandpaper glued to it. You would go that route after you file and are doing the detail sanding.
01-15-2017, 01:55 AM #9
Was checking the boat out yesterday and was trying to get an idea of what it weighed.... from the looks of it it has never had the floor or transom replaced and on the outside it looks great other than 1 hairline crack where the jack plate is mounted. I've read numerous threads trying to find out how many different lay ups were offered in 95 but am hitting a brick wall. I don't have a set of scales yet to weigh it but if I were to guess I'd say around 750 + or - .
01-15-2017, 02:15 AM #10
You can buy a digital hanging scale like I did and hook it to a 4x4 winch and lift it quite easily. Thats what I did.
01-15-2017, 08:11 AM #11
That is a sharp looking boa
1986 cougar mtr 21
2003 supra launch ssv
01-15-2017, 03:17 PM #12
In the process of painting it. White with brandywine
01-25-2017, 09:25 AM #13
Motor's on its way to Jay Smith for some goodies can't wait to get it back!
02-03-2017, 09:04 PM #14
So I just got my bill for FedEx $1677.59. I was originally quoted 470 something. I shipped with the weight set at 270 with the crate and somehow FedEx recalculated it to 450 lbs. Idk if it would do any good to try and dispute this or just pay the bill. Either way I'm still under what I expected to pay to get a motor built by jay but damn 17 for shipping!
02-03-2017, 09:11 PM #15
WOW.....They're rapeing you!!!!
There's no way a powerhead weighs that much, hell the whole engine only weighs about 400....I sent a block UPS, Ok to Wisconsin for less than 100 but it was bare!
BTW, I NEVER use Fedex!!Last edited by WillySteve; 02-03-2017 at 09:15 PM.
Summerford's hybrid hull
By lakeracer1 in forum General Boating DiscussionReplies: 2Last Post: 07-29-2015, 07:39 AM -
Summerford Decal or STV info needed
By us1ss in forum General Boating DiscussionReplies: 3Last Post: 08-15-2012, 02:53 PM -
F-12 cat hull - anyone have any info?
By FlatSleek in forum General Boating DiscussionReplies: 7Last Post: 01-18-2011, 07:41 PM -
Looking for Summerford LTV info?
By mxz in forum Technical DiscussionReplies: 24Last Post: 04-12-2004, 11:29 AM -
CONTACT info for Mr. LAMKIN and Mr. SUMMERFORD??
By AnthonySS in forum General Boating DiscussionReplies: 3Last Post: 07-19-2001, 03:40 PM
