Results 1 to 6 of 6
12-15-2016, 09:32 AM #1New Member
- Dec 2016
- Apple Valley CA
Flat bottom v drive leaps and hops uncontrollably at full throttle no matter what I d
I have a 73 Sanger 18'10" sk4 filling flat. That just won't take a set. Is this a prop shape issue? I even put a 4" longer plate. I
12-19-2016, 08:10 PM #2Team Member
- Lake Coochiching, Ontario
- 7,753
- 271
- 485
- 1572
- 6 Post(s)
Not too many V drives now except wakeboard boats. Have you tried Wilkes Marine? You can get their contact info thru Google. Jim Wilkes used to write about V drives in Hotboat magazine.
12-19-2016, 08:15 PM #3
go here.....http://www.performanceboats.com/v-drives/
12-19-2016, 08:26 PM #4
I've owned and rigged a bunch. With no other info and if your turning the correct prop it's a weight issue. I've moved big blocks 6-8 inches forward to get them to settle down.
Dago
FastLaser, XstreamVking liked this post
01-03-2017, 07:04 AM #5New Member
- Dec 2016
- Apple Valley CA
01-10-2017, 01:58 AM #6
depends on your HP and livable engine rpm... ive got one with a 1:1 and a 13x17 to pull the engine down to safe pontiac RPM id wanna see it run but its most definetly a weight in wrong spot or to much stern lift issue... a bow will lift pretty easy until about 50 mph then the cav plates really start pushing back down and can put you into a uncontrollable sine wave of stern lift bow dig and lift... set the plates TRUE LEVEL then slightly up and slightly down to see which way hop improves ...
Thunder Bolt Flat bottom V drive in MI
By VernG in forum Jet Boats, V-Drives and Stern DrivesReplies: 0Last Post: 02-28-2010, 02:02 PM -
flat bottom v drive?
By still-floatin in forum Technical DiscussionReplies: 9Last Post: 09-12-2007, 06:12 PM -
Converting a V-drive flat bottom to O/B
By moore in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 05-31-2004, 10:50 PM -
Flat Bottom
By delawarerick in forum General Boating DiscussionReplies: 11Last Post: 05-06-2002, 10:00 AM
