Results 1 to 9 of 9
Thread: 30 or 32 cleaver
12-06-2016, 11:40 AM #1
30 or 32 cleaver
Looking to buy my top speed prop over the winter. Really don't care about anything but posting high numbers with this one so I figure the mercury 14.5 x 30 or 32 is going to do the trick. I once borrowed a 32 and posted a number of 106 at 7400 rpm with a 280. The motor does have 260 electronics so I don't have to worry about a rev limiter.
Do you think it would be faster to run a 30 and try to get up around 8000 or is it faster to run a bigger wheel. I've heard from both sides just want to hear more people's opinions. Let me know what your experiences have been.Hydrostream V-king 2005 280
12-06-2016, 12:05 PM #2
Only way to know for sure is try. What works for one boat might not work on yours and vise versa.
12-07-2016, 07:51 AM #3Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
I would run the bigger 32'' wheel if the boat will plane off w/it. My best was near 100 with my King, running a tweaked 30p cleaver at 7500 on a 245 hp bridge port. 106 is really screaming and flying! I take it you tap the trim down as you get past 90? Using a windshield or no? You are now at 12% slip at 106 w/the 32. I don't think that going down in pitch would lower slip, even with the increase in rpm's. All props are different tho...
12-19-2016, 05:54 AM #4
all the cleavers ive ran had around same slip as you or higher.....the 30" @ 12% 8k...still gives ya 106ish
have you tried a 30et?? if motor will turn 8k (i would think it would with right setup) you might have less slip....???81' HYDROSTREAM VECTOR / slightly Modified 200
12-19-2016, 06:53 AM #5
Run a 26" and turn it 9000 call it a day
12-19-2016, 07:03 AM #6
Only reason to run a big wheel is fuel economy or a rev limiter.
Small props will drive easier and let the motor turn up where it wants to be.
280 with 260 electrics will turn 9000 no problem.why run 7400 like a dog.
If your just makin speed passes why use the whole lake when u can do the same speed in half distance.
For river runnin long distance.... Maybe a bigg prop is the ticket for fuel econ and less wear on motor .
But for top speed passes on a 280 with no limiter its a no brainer.
24 or 26 and let her ripp.
12-19-2016, 07:26 AM #7
I agree....but guess u ain't seen his videos...boy don't let off till tank empty
Kcraft liked this post
12-19-2016, 07:56 AM #8Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
28 Labbed ET gives 6% slip on my King...
texasvector liked this post
12-22-2016, 05:56 AM #95000 RPM
- Sep 2013
- sarasota, florida
- 748
- 12
- 12
- 48
river,,no brainer ,,you haven't a clue ,,go play with your ski
32 cleaver counter & a pair 28 cleaver fat shaft
By pablo in forum Propellers WantedReplies: 2Last Post: 09-23-2016, 11:37 AM -
Mercury Lab Cleaver vs. Mazco Cleaver
By 4Speed in forum Props, Setup, and RiggingReplies: 1Last Post: 08-04-2016, 08:48 PM -
WTB Semi cleaver or cleaver prop for a SLT
By scottistang in forum PropellersReplies: 2Last Post: 09-11-2015, 02:29 AM -
Mercury 3 blade Lab cleaver vs. 4 blade lab cleaver
By 4Speed in forum Props, Setup, and RiggingReplies: 5Last Post: 03-22-2015, 10:21 PM
