Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 49
    Phoenix 32 XPR Poker Run
    This thread will remove the ambiguities from the other thread that I started which mixes up the race model "XR" from this Poker Run model "XPR"
    Smart Marine's Poker Run boat ==> https://www.facebook.com/SmartMarineService/
    build pics are depicted in reverse-build order
  2. Likes Capt.Insane-o liked this post
    Hull #2 is the Phoenix XPR (Poker Run boat)
    After the hull prep is complete, will go to DHD (Doug Harrell Designs) for painting then will be rigged with 400R motors
    Phoenix 32 XPR in epoxy primer white
    click on image
  5. Likes tom kennedy, NICE PAIR liked this post
    Can't wait to see this rigged and running.
    Discovery Bay, CA
    What are the true dimensions of this boat? I've seen their raceboat called a 30', and this one a 32'. What is the measurement from the back of the transom to the front of the sponsons? And what is the width? I hope they're not including that duckbill hanging off the back in their LOA. Regardless of being very similar to the DW32, the boat has great lines. Any word on the speeds they're seeing with the raceboat?
    Rayzor, the 30 model was a remade Skater hull.
    The Phoenix is a 32.
    Don't know the specs on it though.
    Discovery Bay, CA
    Got it, makes sense now. I do wonder still what the true specs are on it. It's great to see that buyers are now getting more choices in the large-size outboard cat market.
    The Phoenix 32 without the diffuser is 32' 6" from transom to bow
    the tunnel width on the 30X is 63"
    The Phoenix 32 Poker Run (model name 32 XPR) has been primed and is ready for paint
    click on image
  12. Likes tom kennedy, NICE PAIR, joneill liked this post
    Damn... I needed to start saving 30 years sooner.
  14. Likes noli, NICE PAIR liked this post
    Nov 2010
    Dubuque iowa
    Can not wait to see this when completed!!!! WOW
  16. #12
    The Phoenix 32 XPR was lifted with one strap to determine where the CG (center of Gravity) is located. The guys at SmartMarine couldn't be any happier. The CG location and the hull weight all came in as expected
  17. Likes AZMIDLYF, NICE PAIR liked this post
  18. #13
    So theoretically, that is where they feel the best point for CG is? I can see a static CG on a Vee hull but the Cats have all the Aero working on it.
    What did the hull end up weighing?
  19. #14
    Dec 2015
    Yes, CG for the bare hull came out where we've anticipated. The XPR hull CG is just an inch aft of the XR. We use this as a baseline to establish a rigging layout so that whether the hull receives 300XS's or 400R's, the equipment balances the CG to where we've found the hull to perform best.
  20. Likes NICE PAIR liked this post
  21. #15
    Do the tanks get mounted at the CG point so fuel load doesn't affect the CG balance?
  22. Likes NICE PAIR liked this post
  1. Phoenix Predictions......
    By njj502 in forum The Scream And Fly Lounge
    Last Post: 11-10-2008, 03:23 PM
  2. Vacationing in Phoenix AZ
    By Euroski in forum General Boating Discussion
    Last Post: 03-17-2003, 09:58 PM
  3. Phoenix?
    By tlwjkw in forum General Boating Discussion
    Last Post: 10-05-2002, 09:02 AM
