Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 53
    Adding cup to a stainless prop AT HOME !!!
    I need to add cup to the tips of a stainless prop AT HOME , no sending out to prop shops, this has to be done at home or by the river !!
    the prop is only going to be experimental so if it goes tits up then so be it. I need to be able to bend the tips and possibly a bit of the trailing edge to
    get what I am after.
    I need lots of extra tip cup and possibly a slight bit more cup to trailing edge. The tips I want to make like a large kitchen spoon for shape, sounds very
    different to what I have in my mind. ha ha
    I need to get a normal tip to look like the one below in Picture B for example.
    So what amount of heat is needed to help me get the stainless to bend without weakening it too much. ?
    I got told 200c should do it, and then another fella said get it a dull red ?
    would small propane torch be enough heat to get it to work a bit easier ? I am not worried about discolouration as that can be dealt with easy enough .t
    this job I need to do myself, as it is going to be a do a little bit and try, do a little bit and try etc etc.
    any thoughts on this ?
    The pics below show the sort of thing I need to do.
    prop B is a pic of a srx with added tip cup from DAH, and Prop A is my srx with no extra cup added.
    prop I will be experimenting on is a different prop but this shows what sort of tip cup I need to get on a non tip cupped propeller .
Name:	SRX NEED CUP.jpg
ID:	360959   Click image for larger version.
Name:	dah srx bowlift 2.jpg
    Sep 2016
    SF Bay Area
    The old race boys used a trailer ball on a 2" pipe stand filled with sand. They used the trailer ball from the pull truck at the races to "fix" issues - cold.
    Not saying it's a good idea. but ...
  3. Likes whipper liked this post
    I have seen brass(bronze) props beaten on a trailer ball but never SS. If thats the case that could open a whole new world! Gary
    "77" Hydrostream Viper "87" 140 Rude heavy modded w/15" mid, Bobs nose and lwp (in progress)
    Quote Originally Posted by phillnjack View Post
    Take a look @ this > http://www.pitchblock.com/pitch-blocks.html
  6. Likes olboatman liked this post
    Juneau, WI
  8. Likes NICE PAIR liked this post
    Buying a pitch block is way too expensive for just home use. Run quiet have nice stuff but the use far too many digits in their price menu.
    I don't need a mandrel, I can make that easy enough and strong. I need to be sure I can just bash the stainless cold and not harm it.
    I agree about the pitch block but why cant you heat the tips to 1700 deg F as seen on the other site? Gary
  11. Thanks David - WI thanked for this post
  12. #8
    Cheers Gary you have just answered the question I was looking for , 1700deg f is the heat needed to use for stainless, I presume thats what you meant.
    1700F is a bit different to 200deg C that I got told.. i didn't think 200C would be enough to make much difference .
    I make 170-F around 920 deg C... thats a bit warm ha ha . (have to remember not to touch it)...
    will try on a bit of scrap stainless to see if my little torch can get it up to that temp.
    I will just weld up a mandrel and give it a go with the propane if I can get the heat in the tips. if it works, then brilliant, if it dont then its another on my ever growing list of fails.
  13. #9
    Cincy Ohio
    I've done a ton of them. Mostly aluminum but some stainless and brass.
    The stainless I've done, were thin enough I didn't need heat.
    My pitch blocks were pressure treated 2x4's and 4x4's. Many dock posts happen to be 4x4's as well
    I like to experiment and I've had many, ugly, beat on props be as fast as my fastest.
    No one will buy them, but they ran
    And just to qualify this method, I used to race kneel down outboard and one of our good prop guys used to take a wooden chair to the races and one of it's vertical back supports just happened to end in a perfect radius.
    That was his pitch block.
    Pitted beside him once during testing and saw a guy bring him a prop telling him its issues. He looked at it, put it on his pitch block and tapped on it a minute or two and handed it back.
    The guy came back and hr later telling him how well it ran!
    Beating on cheap props is big fun in m world.
    Checkmate Starliner Frank III
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    28' Marinette Express
    32' Marinette Flybride Sedan
  14. Likes olboatman, Slimm liked this post
  15. #10
    Apr 2013
    Lexington, ky
    The rundquist site says "Heat the propeller first, never going above 1700 degrees F." I think what they are saying is stay in the 13-1500 area to be safe maybe?
    Slimm
  16. #11
    Quote Originally Posted by SlimmDaddy View Post
    Slimm
    Good point Scott ! Ya wouldn't want to weaken it. Gary
  17. Likes Slimm liked this post
  18. #12
    May 2001
    The Villages, Florida
    I use to get a big piece of brass and grind the cup profile I wanted into it and mount it in a very large vise. I would then lay the prop over the brass and use a lead hammer to add the cup. Doing it this way does not mark the propeller as much.
  19. Likes Mr. Demeanor, Magcat 62 liked this post
  20. #13
    Feb 2005
    go to a welding shop and get a temp stick for the temp your going to use.
    land and sea had a guage for cupped prop several years ago. they may not be accurate to the n th degree but can give you a consistent measure.
  21. #14
    Juneau, WI
    Downloadable template for pitch measuring: http://www.propellerhub.com/simple-pitch-measuring
  22. #15
    Thanks guys, this all sounds like real good advice.
    I do plan on making a device to get the cup all the same on all 3 blade tips, I will get all of them the same so not too worried about the actual pitch on the tips..
    one prop i have is a good prop, but something I wont use much at all,( only 17 pitch) so that will be my test prop as in testing on the boat.
    fir my first attempt at getting a tip bent over i will sacrifice a alloy prop thats already crap. so that can be the prototype ( sound better than guinee pig ha ha)
    i already have that pitch measuring app, its fairly accurate on the whole. i have a few templates printed out.
    used it last year to identify a tohatsu prop with no markings, turned out we got it within 1/4 inch of its true pitch !!!
  23. Likes Slimm, NICE PAIR liked this post
  1. Adding cup to a propeller at home
    By mrpenguin in forum Technical Discussion
    Last Post: 10-02-2013, 09:13 AM
  2. Effects of moving prop back on propshaft? (adding a second trust washer)
    By Mr. Demeanor in forum Props, Setup, and Rigging
    Last Post: 02-14-2011, 09:21 PM
  3. Adding setback or work prop?
    By bluecheckmate in forum Props, Setup, and Rigging
    Last Post: 08-10-2010, 01:37 PM
  4. adding a stainless marine twin bracket
    By advancedmarine in forum Fiberglass and Composites Discussion
    Last Post: 01-23-2008, 02:21 PM
  5. Ventilating a prop at home?
    By Pro300x24LD in forum Props, Setup, and Rigging
    Last Post: 09-18-2007, 05:58 PM
