Results 1 to 15 of 22
    Apr 2013
    Lexington, ky
    WMV-WMH carb info
    I have been doing a lot of searching and reading here as well as several other forums and websites on the 'net about the WMV-WMH carbs and have noticed a considerable amount of misinformation and misunderstanding. I have spoken with several people that use them with success and even got lucky enough to chat with someone at Mercury. I have what I believe to be a good understanding on them now and thought I would share what I have learned in hopes it may help someone else in the future or at least be a source of reference. If someone comes across this and has more/better knowledge than I do, please let me know if I have some inaccurate information so that I can change it. I am still struggling to locate a source for the idle air vent jet part numbers/sizes and will update this post with that info if/when I get it.
    WMV and WMH CARBS
    REDUCE IDLE AIR VENT JETS 2 SIZES: Idle air vent jets add more air to the air/fuel mixture, making it leaner. The bigger the jet the LEANER the mixture, smaller the jet is RICHER. Start 2 jet sizes smaller, according to Jay with SST Marine this should put your EGT @ aprox 1050 degrees.
    REMOVE THE BACK DRAFT JET - it restricts air flow into the fuel bowl: removing it allows more fuel to flow out of the bowl in response to increased throttle.
    MAIN JETS:
    If you don't have a EGT you should go up 2 sizes on the main fuel jet, you may lose 100-200 RPM up top but this should be a safe place to start.
    If you have an EGT you can go up 1 size and monitor your exhaust temps and then increase jet size as needed to ensure nothing melts. Remember, Lean is mean but fat is where it's at
    Here is a chart with Mercury carb jet part numbers and sizes, Vnemous gets credit for sending me this since I couldn't find it when I needed it
    Here is a WMV-18 carb view with jets labeled
    I'll post more info as I get it.
    Slimm
  2. Thanks 90 5.0 thanked for this post
    minocqua, wis
    here is what i know after 12 years running rich with wmh 39's
    on 245's
    off idle 48
    idle 72
    no back draft
    mains 68
    16 gallons gas per side 2 hours completely empty
    i figured i,m going to redo these so i may as do some jetting
    off idle 50
    idle 58
    back draft 92
    mains 68 1/3/4/6 70 2/5
    16 gallons gas per side 3 hours running till empty
    pistons tops are starting to clean off after couple hours pic 1 piston from each motor , and ran better i still have some tweaking when power heads are done
    was thinking go to wmv's but i think stay with wmh but get some 47's off 3.0 liter should be more close jetted for 245's
  4. Likes Slimm liked this post
  5. #3
    Apr 2014
    metairie louisiana
    Pm sent
    Jun 2004
    port st. lucie, fl
    i've never played with the wmv' but have used quite a few wmh's on alot of the builds, basically it is a 3 circuit carb(unlike the old wh series). as said, toss the backdraft jets, progression jets affect your midrange(in the carb throat area), they are air jets, so it is the opposite as stated aboved, increase the size to lean out. mains are in the bowls and are normal(increase size to richen). i haven't had to play with the idle side jetting, as you can adjust the mixture screws and usually wind up where you need to be. these carbs are much more sensitive to jetting changes as compared to the wh series. one thing i will say that i've found, try to start with a set off a 200 or a 245, as the internal drilling/passages are different from different horsepower models, even though the venturi/buterfly size is the same. tried years ago to use a set off a 150, but rejetted them and could never get them to run quite rite. there is a number stamped in the side of the carb mount flange, will begin wmh 21-1,-2,-3. the -1,-2,-3 is placement from top to bottom, and 21 would be the series(what engine it went on). i'll try to get some pics later of the application chart posted. one important note, for example,because someone used a 66 main in a wmh doesn't neccesarily mean it will work in another wmh unless it is the same series number, as the internal passages on some were different.
  7. Thanks Slimm thanked for this post
    Jun 2004
    port st. lucie, fl
ID:	360057Click image for larger version.
ID:	360058Click image for larger version.
ID:	360059Click image for larger version.
ID:	360060Click image for larger version.
ID:	360061Click image for larger version.
  9. Thanks Slimm thanked for this post
  10. #6
    Jun 2004
    port st. lucie, fl
    Here is an example of the main jetting on a 1993 245 hp engine. I don't have any carb series numbers for the 245, but from what I've seen it will be a 4 digit number or begin with an 'x'. Click image for larger version.
  11. #7
    Apr 2013
    Lexington, ky
    Thank you for the input Charlie. I was hoping some more knowledgeable folks would chime in.
    Quote Originally Posted by mrcrsr View Post
    ... progression jets affect your midrange(in the carb throat area), they are air jets, so it is the opposite as stated aboved, increase the size to lean out..
    I noticed after posting this that WMH carbs are a little different than the WMV. The WMH carbs have 'progression' jets that affect midrange, where the WMV carbs have 'idle air vent jets' that affect idle and off-idle?.
    I have wondered quite a bit about that. Dave Strong and I have been chatting about these carbs quite a bit and I just mentioned to him my curiosity about them using the same carb series (ex. WMV-15) for such a wide range of engine displacement. I have thought there had to be something inside that was different.
    Thank you, that would be greatly appreciated. Hopefully there can be enough info gathered in one place to help those just starting with these carbs get a better understanding of how they work and how to tune them.
    Slimm
  12. #8
    Apr 2013
    Lexington, ky
    WOW thanks, That is great information. Do you have charts/listing for the WMV series carburetors ?
    Slimm
  13. #9
    Jun 2004
    port st. lucie, fl
    Slimm, take a look at the above posted pics from the mercury service manual. Our scanner is not working so I took pics of the pages. U can see the difference in jetting between the various wmh series carbs, even though they share the same venturi size. also the 1990 to roughly 91/92 200's were 7 petal engines as far as the reeds, same with the 245 which would effect the internal passages (how the carbs are made)
  14. Thanks Slimm thanked for this post
  15. #10
    Jun 2004
    port st. lucie, fl
    Here's what I have for the wmv series. Click image for larger version.
ID:	360066Click image for larger version.
ID:	360068Click image for larger version.
  16. Thanks Slimm thanked for this post
  17. #11
    Jun 2004
    port st. lucie, fl
    They also used the wmv on 3 litre mercury, so keep that in mind
  18. Thanks Slimm thanked for this post
  19. #12
    Jun 2004
    port st. lucie, fl
    This is how the off idle (progression ) works in the wmh. Click image for larger version.
  20. Thanks Slimm thanked for this post
  21. #13
    Jun 2004
    port st. lucie, fl
    And wmv. Click image for larger version.
  22. #14
    Jun 2004
    port st. lucie, fl
    Quote Originally Posted by SlimmDaddy View Post
    Slimm
    Alot of people use the wh (2.4) carbs on the 2.5. To me, it's the difference between using something designed on a chalkboard vs a computer. The wh are easy to set up (2 circuit carb) whereas the wmh is 3 circuit. It's more complex to set up but the end results are better, engine is more efficient and there is less stuff to go wrong, 2 needles and seats vs 1 per carb. people use what they are comfortable with.
  23. #15
    Apr 2013
    Lexington, ky
    I have a 2002 Mercury Service Manual that shows the same info for the backdraft and off-idle description. I am an old school car hot rod/race car guy so carbs are not something I am scared of which is why I feel so comfortable opening them up and changing things. My boat friends around here are scared to death of anything 'non-factory' and refuse to try or change anything from the way it left the factory. I love tinkering and trying to understand how things work and what was going through the minds of the people that created whatever 'thing' I am intrigued by at the moment, which happens to be these carburetors at the moment hahaha.
    Do you think there is enough adjustment in the idle mixture screw to not worry about the idle air jet itself and focus more on the main fuel jet, or will the idle air jet alter mid-range mixture enough to warrant some adjustment?
    Slimm
  1. 80' 225 carb info..
    By CKMATE225 in forum Technical Discussion
    Last Post: 11-02-2012, 01:06 PM
  2. odba pro carb info
    By YELLOWSS in forum Technical Discussion
    Last Post: 01-06-2011, 11:31 PM
  3. Mercury Tech: 2.4 200 89 carb motor info
    By bigbluechevy454 in forum Technical Discussion
    Last Post: 09-14-2009, 08:10 PM
  4. Need Carb Info
    By hawktuner in forum Technical Discussion
    Last Post: 11-07-2005, 10:01 AM
  5. carb info?
    By mercrazy in forum Technical Discussion
    Last Post: 11-12-2001, 05:38 AM
